My refurb Optiplex 755 SFF not USFF just got here today, and I realized that the Graphic card a GT520 will not fit in it. (in the rush of trying to get everything here before Christmas I didn't make sure it was a low profile card). Luckily I'll have a machine I can put it in soon. If not I'll prob trade or give it away (Happy Holidays) Just wanted recommendations for a card that will fit and do the job of providing hdmi out with sound. Initial setup will be Ubuntu. Also in the market for a tuner card. I know this question has been asked to death but many of the cards recommended are either out of stock or discontinued.
I switched out my radeon 4350 for asus radeon HD6570 which works fine driving a 1080p projector via hdmi and a 1080p led monitor via dvi. If you re into gaming, them you need something more powerful. But for movies, it should do the trick.
Asus link:
http://www.asus.com/Graphics_Cards/AMD_S...0DI1GD3LP/
Can you just remove the "high profile" plate? most cards have the vga port removable for low profile use. I did this for my gt430.
(2012-12-25, 06:52)EricHoya Wrote: [ -> ]I switched out my radeon 4350 for asus radeon HD6570 which works fine driving a 1080p projector via hdmi and a 1080p led monitor via dvi. If you re into gaming, them you need something more powerful. But for movies, it should do the trick.
Asus link:
Thanks for the tip. It's not for gaming just a box for the house. Just needed a little more flexibility than some of the smaller more dedicated boxes offer as I also run plex.
(2012-12-25, 15:00)N3MIS15 Wrote: [ -> ]Can you just remove the "high profile" plate? most cards have the vga port removable for low profile use. I did this for my gt430.
I see what you mean :-) will try picking up one of these
http://www.ebay.com/itm/GeForce-GT-405-4...1c2def4328 as I really wont need the VGA port will let you know how it goes. Thanks
Just to let you know I bought the LP plate and got the card installed.
