2012-12-26, 05:59
Quote:22:42:37 T:6800 INFO: CFileCache:rocess - Hit eof.
22:42:37 T:6800 DEBUG: Thread CFileCache 6800 terminating
22:42:37 T:5460 DEBUG: CFileCache::Open - opening <svn/trunk/addons.xml.md5> using cache
22:42:37 T:5460 DEBUG: CurlFile::Open(08655A08) http://xbmc-adult.googlecode.com/svn/tru...ns.xml.md5
22:42:37 T:5460 INFO: XCURL:llLibCurlGlobal::easy_aquire - Created session to http://xbmc-adult.googlecode.com
22:42:37 T:6508 NOTICE: Thread CFileCache start, auto delete: false
22:42:37 T:6508 INFO: CFileCache:rocess - Hit eof.
22:42:37 T:6508 DEBUG: Thread CFileCache 6508 terminating
22:42:37 T:5460 DEBUG: CFileCache::Open - opening <addons/frodo/pvr/win32/addons.xml.md5> using cache
22:42:37 T:5460 DEBUG: CurlFile::Open(085E0DA0) http://mirrors.xbmc.org/addons/frodo/pvr...ns.xml.md5
22:42:38 T:6888 NOTICE: Thread Jobworker start, auto delete: true
22:42:38 T:5460 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 22
22:42:38 T:5460 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
22:42:38 T:5460 ERROR: XFILE::CFileCache::Open - failed to open source <http://mirrors.xbmc.org/addons/frodo/pvr/win32/addons.xml.md5>
22:42:38 T:5460 DEBUG: CurlFile::Open(073589D0) http://mirrors.xbmc.org/addons/frodo/pvr...addons.xml
22:42:38 T:224 DEBUG: JSONRPC: Incoming request: { "jsonrpc" : "2.0" , "method" : "Files.GetDirectory" , "params" : { "directory" : "C:\\Users\\Aaron\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\weather.wunderground\\map" , "sort" : { "method" : "file" } } , "id" : 1 }
22:42:38 T:224 DEBUG: JSONRPC: Calling files.getdirectory
22:42:38 T:224 DEBUG: CUtil::GetMatchingSource: no matching source found for [C:\Users\Aaron\AppData\Roaming\XBMC\userdata\addon_data\weather.wunderground\map]
22:42:38 T:5460 DEBUG: Previous line repeats 3 times.
22:42:38 T:5460 ERROR: Repository XBMC.org PVR Add-ons returned no add-ons, listing may have failed
22:42:40 T:224 INFO: Scriptresult: Success
22:42:40 T:224 INFO: Python script stopped
22:42:40 T:224 DEBUG: Thread XBPyThread 224 terminating
22:42:40 T:1384 DEBUG: waiting for python thread 7 to stop
22:42:40 T:1384 DEBUG: python thread 7 destructed
22:42:40 T:8036 DEBUG: CZipManager::GetZipList - Processing zip://special%3a%2f%2fxbmc%2fmedia%2fweather.zip/
22:42:40 T:8036 DEBUG: POParser: PO file has Win Style Line Endings. Converted in memory to Linux LF for file: special://xbmc/language/English/strings.po
22:42:40 T:8036 DEBUG: POParser: loaded 109 weather tokens
22:42:42 T:1384 DEBUG: CApplication:rocessMouse: trying mouse action wheeldown
22:42:47 T:1384 DEBUG: Previous line repeats 7 times.
22:42:47 T:1384 DEBUG: CApplication:rocessMouse: trying mouse action leftclick
22:42:47 T:1384 DEBUG: CApplication::ExecuteXBMCAction : Translating SetProperty(SubMenuBackground,$VAR[CommonScreenBackground],Home)
22:42:47 T:1384 DEBUG: CApplication::ExecuteXBMCAction : To SetProperty(SubMenuBackground,special://skin/backgrounds/homescreen/shutdown.jpg,Home)
22:42:47 T:1384 DEBUG: CApplication::ExecuteXBMCAction : Translating XBMC.Quit()
22:42:47 T:1384 DEBUG: CApplication::ExecuteXBMCAction : To XBMC.Quit()
22:42:47 T:1384 DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
22:42:47 T:1384 DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnQuit
22:42:47 T:6888 DEBUG: Thread Jobworker 6888 terminating (autodelete)
22:42:47 T:8028 DEBUG: Thread Jobworker 8028 terminating (autodelete)
22:42:47 T:8036 DEBUG: Thread Jobworker 8036 terminating (autodelete)
22:42:47 T:1384 NOTICE: Storing total System Uptime
22:42:47 T:5460 DEBUG: Thread Jobworker 5460 terminating (autodelete)
22:42:47 T:1384 NOTICE: Saving settings
22:42:47 T:1384 NOTICE: stop all
22:42:47 T:1384 INFO: stopping PVRManager
22:42:47 T:1384 DEBUG: CNetwork::NetworkMessage - Signaling network services to stop
22:42:47 T:1384 NOTICE: ES: Stopping event server
22:42:47 T:1384 DEBUG: CNetwork::NetworkMessage - Waiting for network services to stop
22:42:47 T:1384 NOTICE: stopping zeroconf publishing
22:42:48 T:7152 NOTICE: ES: UDP Event server stopped
22:42:48 T:7548 DEBUG: Thread CTCPServer 7548 terminating
22:42:48 T:7152 DEBUG: Thread CEventServer 7152 terminating
22:42:48 T:6556 DEBUG: Thread XBMC Peripherals 6556 terminating
22:42:48 T:1384 NOTICE: stop sap announcement listener
22:42:48 T:1384 NOTICE: clean cached files!
22:42:48 T:1384 NOTICE: unload skin
22:42:48 T:1384 INFO: Unloading old skin ...
22:42:48 T:1384 DEBUG: ------ Window Deinit (Home.xml) ------
22:42:48 T:1384 DEBUG: ------ Window Deinit (Pointer.xml) ------
22:42:48 T:1384 DEBUG: CTextureBundleXBT::Cleanup - Closed theme bundle
22:42:48 T:1384 DEBUG: CTextureBundleXBT::Cleanup - Closed bundle
22:42:48 T:1384 DEBUG: ADDON: Stopping service addons.
22:42:48 T:1384 INFO: Stopping script with id: 1
22:42:48 T:6776 DEBUG: Skin Widgets: script version 0.0.19 stopped
22:42:48 T:6776 INFO: Scriptresult: Success
22:42:48 T:1384 DEBUG: XBPyThread:top - script termination took 91ms
22:42:48 T:1384 INFO: Stopping script with id: 4
22:42:48 T:6776 DEBUG: The python script "C:\Users\Aaron\AppData\Roaming\XBMC\addons\service.skin.widgets\default.py" has left several classes in memory that we will be attempting to clean up. The classes include: Window,Player,Monitor
22:42:53 T:1384 ERROR: XBPyThread:top - script didn't stop in 5 seconds - let's kill it
22:42:53 T:6776 DEBUG: It took 1 Py_NewInterpreter/Py_EndInterpreter calls to clean up the classes leftover from running "C:\Users\Aaron\AppData\Roaming\XBMC\addons\service.skin.widgets\default.py."
22:42:53 T:6776 INFO: Python script interrupted by user
22:42:53 T:6776 DEBUG: Thread XBPyThread 6776 terminating
22:42:53 T:7484 NOTICE: StorageServer-1.3.0 Closed down
22:42:53 T:1384 INFO: Stopping script with id: 5
I cut the first half or so out to make it fit under 10k characters
