2012-12-26, 16:13
I'm new at this - and I think your product is fantastic. I have it running on an old ATV2 and it works great.
I'm trying to install it on my SAMSUNG laptop.
Other symptoms:
- Once the splash screen is frozen, Task Manager shows XBMC as non responsive
- I am unable to end the XBMC program, only rebooting the PC ends the program and then I have to manually turn it off and turn it back on again for reboot
- FRODO starts just fine, but eventually also locks up with same problem in ending the program and manual reboot
I think the problem is my graphics card? And since this is a laptop, I don't have any way of upgrading/changing it.
There are two errors in the log file below. It seems to recover form one of them but after the second one, the program freezes
21:12:38 T:6028 ERROR: special://masterprofile/guisettings.xml, Line 0
Failed to open file
21:12:38 T:6028 ERROR: Unable to load special://masterprofile/guisettings.xml, creating new special://masterprofile/guisettings.xml with default values
21:12:40 T:5128 ERROR: CRemoteControl::Connect - failed to connect
OS Name Microsoft Windows 7 Home Premium
Version 6.1.7601 Service Pack 1 Build 7601
SAMSUNG System Model RC512
System Type x64-based PC
Processor Intel® Core i5-2410M CPU @ 2.30GHz, 2301 Mhz, 2 Core(s), 4 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 01FN.M038.20110817.SSH, 8/17/2011
SMBIOS Version 2.7
Memory (RAM) 8.00 GB
Total Physical Memory 7.91 GB
Available Physical Memory 5.43 GB
Total Virtual Memory 15.8 GB
Available Virtual Memory 12.4 GB
Page File Space 7.91 GB
GRAHICS
Name Intel® HD Graphics Family
PNP Device ID PCI\VEN_8086&DEV_0116&SUBSYS_C0AE144D&REV_09\3&11583659&0&10
Adapter Type Intel® HD Graphics Family, Intel Corporation compatible
Adapter Description Intel® HD Graphics Family
Adapter RAM (247,273,472) bytes
Installed Drivers igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx32,igd10umd32,igd10umd32
Driver Version 8.15.10.2266
INF File oem8.inf (iSNBM0 section)
Color Planes Not Available
Color Table Entries 4294967296
Resolution 1366 x 768 x 59 hertz
Bits/Pixel 32
Memory Address 0xF5C00000-0xF5FFFFFF
Memory Address 0 xE0000000-0xEFFFFFFF
I/O Port 0x0000E000-0x0000E03F
IRQ Channel IRQ 4294967284
I/O Port 0x000003B0-0x000003BB
I/O Port 0x000003C0-0x000003DF
Memory Address 0xA0000-0xBFFFF
21:12:38 T:6028 NOTICE: -----------------------------------------------------------------------
21:12:38 T:6028 NOTICE: Starting XBMC (11.0 Git:20120321-14feb09), Platform: Windows 7, 64-bit (WoW) Service Pack 1 build 7601. Built on Mar 21 2012 (compiler 1600)
21:12:38 T:6028 NOTICE: Intel® Core i5-2410M CPU @ 2.30GHz
21:12:38 T:6028 NOTICE: Desktop Resolution: 1366x768 32Bit at 60Hz
21:12:38 T:6028 NOTICE: Running with restricted rights
21:12:38 T:6028 NOTICE: Aero is enabled
21:12:38 T:6028 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
21:12:38 T:6028 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
21:12:38 T:6028 NOTICE: special://masterprofile/ is mapped to: C:\Users\Armando Cuevas\AppData\Roaming\XBMC\userdata
21:12:38 T:6028 NOTICE: special://home/ is mapped to: C:\Users\Armando Cuevas\AppData\Roaming\XBMC\
21:12:38 T:6028 NOTICE: special://temp/ is mapped to: C:\Users\Armando Cuevas\AppData\Roaming\XBMC\cache
21:12:38 T:6028 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
21:12:38 T:6028 NOTICE: Local hostname: Armando-SLaptop
21:12:38 T:6028 NOTICE: Log File is located: C:\Users\Armando Cuevas\AppData\Roaming\XBMC\xbmc.log
21:12:38 T:6028 NOTICE: Setup SDL
21:12:38 T:6028 NOTICE: Found screen: Generic PnP Monitor on Intel® HD Graphics Family, adapter 0.
21:12:38 T:6028 NOTICE: Primary mode: 1366x768 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Additional mode: 320x200 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Previous line repeats 2 times.
21:12:38 T:6028 NOTICE: Additional mode: 320x240 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Additional mode: 400x300 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Additional mode: 512x384 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Additional mode: 640x400 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Additional mode: 1280x600 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Additional mode: 1360x768 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: Additional mode: 1366x768 @ 60.00 - Full Screen
21:12:38 T:6028 NOTICE: load settings...
21:12:38 T:6028 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:12:38 T:6028 NOTICE: loading special://masterprofile/guisettings.xml
Failed to open file
21:12:38 T:6028 NOTICE: Getting hardware information now...
21:12:38 T:6028 NOTICE: Checking resolution 12
21:12:38 T:6028 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:12:38 T:6028 NOTICE: Loaded playercorefactory configuration
21:12:38 T:6028 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:12:38 T:6028 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:12:38 T:6028 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
21:12:38 T:6028 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
21:12:38 T:6028 NOTICE: Default DVD Player: dvdplayer
21:12:38 T:6028 NOTICE: Default Video Player: dvdplayer
21:12:38 T:6028 NOTICE: Default Audio Player: paplayer
21:12:38 T:6028 NOTICE: Disabled debug logging due to GUI setting. Level 0.
21:12:38 T:6028 NOTICE: Log level changed to 0
21:12:38 T:6028 NOTICE: Loading media sources from special://masterprofile/sources.xml
Other symptoms:
Failed to open file
SMBIOS Version 2.7
GRAHICS
Bits/Pixel 32
Failed to open file
