2012-12-26, 16:28
Dear XBMC users,
I have an issue with a new HTPC built of mine.
Problem:
The problem is that when I turn on/off my Logitech DiNovo Edge XBMC locks up and stops working. It just gives me the standard Windows "application crashed" error. I have tried this with a clean install of XBMC 11.0, running Windows 8 64bit.
HTPC specifications:
CPU+GPU: AMD A10-5800K
Mobo: ASUS F2A85-M Pro
Mem: Corsair 8GB DDR3-1600 (of which only 1/2 module is in use, so 4GB)
Audio: ASUS Xonar Essence STX
HDD 1: Crucial m4 128GB
HDD 2: 500GB HDD (Unknown)
Optical drive: LG BH10LS38
Logitech DiNovo Edge connected with a 3rd party bluetooth connector
Hauppage WinTV remote control connected with the provided IR connector
I have tried turning on debugging earlier but I could not find anything useful doing so.If this is a stupid question don't hesitate to rub it in. If it isn't, please, give a helping hand if possible.
Thank you in advance
Problem:
