Full Version: Guide data no longer showing
Hey Guys, I just went to my guide and there's no data, I use the xmltv method to get date to my guide.
I've rebooted, I've restarted the pvr (Mediaportal) and still nothing there.
Am I missing something here?
I've been using xbmc for a couple months now and I've always had guide data since setting up, but today it seems to have vanished.
I have not made any changes
No idea. I've seen that Dushmaniac recently changed EPG related items in the Frodo RC code but not sure if that is related.
In case you also installed MediaPortal, check there if you see EPG data there. If not, you might want to check if the MediaPortal TVServer database itself contains EPG data. E.g. use a program like HeidiSQL to connect to the MySQL database and check the mptvdb\program table.
Enable debug logging in XBMC and check your xbmc.log file for EPG related messages. It might give you more clues.
Thanks margro, there was no data in the mediaportal guide so I just replaced and the xmltv file and everything is working again.
It seems the xmltv file wasn't updating
