Full Version: Aeon Nox 4.0 : Showcase Mod
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
I split the thread from Aeon Nox 3.6.1 mod :
http://forum.xbmc.org/showthread.php?tid=139991
So I mod Live DVD Case background and Showcase view to :
- display BD/DVD or clear case with resolution logo (Live DVD Case, thanks to Fmronan for moving cases to see all resolutions)
- open manually or automatically the case and display the DiscArt
- not display case for movieset in order to provide my own picture
watch gallery
Get mod :
* ZIP file for patching Aeon Nox :
http://code.google.com/p/aeon-nox-4-show...loads/list
* Textures.xbt modified file to get Aeon Nox release number :
http://aeon-nox-4-showcase-mod.googlecod...xtures.xbt
* Square textures for square theme : http://aeon-nox-4-showcase-mod.googlecod...Square.xbt
How to install patch file :
- unzip file
- copy subfolders 1080i and media into Aeon Nox root directory (overwrite existing folders)
Contains :
\media\thumbs\boxes\tvshows\back_*.png : cases background for DVD/BD cases (Thanks to Frodo19)
\media\thumbs\boxes\movies\back_*.png : cases background for clear cases (Thanks to Frodo19)
\1080i\custom_1126_ViewtypeSettings.xml
\1080i\custom_1155_LiveBGContent.xml
\1080i\DialogAlbumInfo.xml
\1080i\Includes_WidgetLayout.xml
\1080i\variables.xml
\1080i\Viewtype_ShowcaseMovies.xml
\1080i\Viewtype_ShowcaseSquare.xml
Add/Mod in XML files :
modifications are between <!-- MikeBZH44 start --> and <!-- MikeBZH44 end -->
Versions :
1.4 : Aeon Nox 4.0.9 compatibility + rolling disc
1.0.1 : Case won't display for current movie when coverflow is OFF
1.0.0 : Initiale
How to open the case :
To open case and display disc art, set Show CDArt option to ON in Showcase view settings.
Case opening is linked to infopanel display so :
* Infopanel = ON : case open immediatly, disc roll into it, stay open 3 sec more and close
* Infopanel = MANUAL : case open when press UP to display info panel, disc roll into it, stay open 3 sec more and close
* Infopanel = DELAY : case open when info panel slide (delay is inherit from info panel setting), disc roll into it, stay open 3 sec more and close
* Infopanel = OFF : case don't open
CAUTION : For Albums view with coverflow OFF, disc art cannot be displayed so case will always open and default CD disc will roll
In order to display CDart in album views, settings have to be done in Aeon Nox :
thanks mate this is awesome. the only probem i use custom disc.pngs and the mod doesnt seem to pick them up anymore, only seems to work through artwork downloader which doesnt let you select your own disc art
Best Belated Christmas Present EVER!!! Fantastic work.
(2012-12-27, 10:41)kurtamery929 Wrote: [ -> ]thanks mate this is awesome. the only probem i use custom disc.pngs and the mod doesnt seem to pick them up anymore, only seems to work through artwork downloader which doesnt let you select your own disc art
Don't know if latest Artwork Downloader include this hack so you can try it :
http://forum.xbmc.org/showthread.php?pid...pid1249529
@mike
with your mod and latest git version of the skin i become this picture if i switch from cover to cover.
there is no case that get open, i see imaditaly the cd cover.
Eisi
Will 4.0 eventually have cdart for music as well or is this not on the cards? (or worse am I missing something).
@eisi : You must use coverflow for the moment.
@Azrielus : I'm working on the same view for albums
@eisi : Try with release 1.0.1
http://passion-xbmc.org/aeon/aeon-nox-4-...ttach=8295
Should work now Big Grin
better start using github, mike^^
this mod will break lot lot of the newer stuff, i wouldn´t recommend to copy and paste those files into our newest GIT version.
Which stuff ? In variables.xml and/or Includes_WidgetLayout.xml ?
How can I do it in github ?
Do I have to fork your skin ? And then mod the files ? And after every commit from you, I will have to make a diff ?
Or I can simply wait to AE4.0 final release and make the mod.
(2012-12-27, 16:38)mikebzh44 Wrote: [ -> ]Which stuff ? In variables.xml and/or Includes_WidgetLayout.xml ?
everywhere. c&p your files into our latest GIT and look at the diff.
(2012-12-27, 16:38)mikebzh44 Wrote: [ -> ]How can I do it in github ?
I won´t explain in detail how GIT works here, that would take too much time.
either read up some tutorials or ask fmronan, he was able to clone and stay up-to-date.
Yes but he spend a lot of time to check every of your commits and I work on the mod at work and github is forbidden by the proxy.
So I will wait for the final release on the repository.
Added in GlassNox (mod Aeon Nox 4.0), thx Mike
http://passion-xbmc.org/addons/?Page=Vie...ss.nox.svn
with your last commit (thx Phil)
Open cases available tommorow morning
Mod available on github :
https://github.com/mikebzh44/Aeon-Nox
I will try to follow Big-Noid and Phil commits Big Grin
Really good work many thanks.
Can you provide this Mod also for the Confluence Skin Mod of mad Max?
I have tried already once this, if it has made not whole, however.
