2012-12-27, 13:02
I reinstalled my HTPC and I have a problem with autologin. I have followed this this.
Here is my log and configuration lighdm.
SeatDefaults]
autologin-user=xbmc
autologin-user-timeout=0
user-session=XBMC
greeter-session=lightdm-gtk-greeter
[+0.01s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.01s] DEBUG: Starting Light Display Manager 1.2.1, UID=0 PID=1199
[+0.01s] DEBUG: Loaded configuration from /etc/lightdm/lightdm.conf
[+0.01s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.01s] DEBUG: Registered seat module xlocal
[+0.01s] DEBUG: Registered seat module xremote
[+0.01s] DEBUG: Adding default seat
[+0.02s] DEBUG: Starting seat
[+0.02s] DEBUG: Starting new display for automatic login as user xbmc
[+0.02s] DEBUG: Starting local X display
[+0.05s] DEBUG: X server :0 will replace Plymouth
[+0.08s] DEBUG: Using VT 7
[+0.08s] DEBUG: Activating VT 7
[+0.08s] DEBUG: Logging to /var/log/lightdm/x-0.log
[+0.08s] DEBUG: Writing X server authority to /var/run/lightdm/root/:0
[+0.08s] DEBUG: Launching X Server
[+0.08s] DEBUG: Launching process 1248: /usr/bin/X :0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch -background none
[+0.09s] DEBUG: Waiting for ready signal from X server :0
[+0.09s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.09s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+2.82s] DEBUG: Got signal 10 from process 1248
[+2.82s] DEBUG: Got signal from X server :0
[+2.82s] DEBUG: Stopping Plymouth, X server is ready
[+2.85s] DEBUG: Connecting to XServer :0
[+2.85s] DEBUG: Automatically logging in user xbmc
[+2.85s] DEBUG: Started session 1556 with service 'lightdm-autologin', username 'xbmc'
[+2.97s] DEBUG: Session 1556 authentication complete with return value 0: Success
[+2.97s] DEBUG: Autologin user xbmc authorized
[+3.01s] DEBUG: Autologin using session XBMC
[+3.05s] DEBUG: Dropping privileges to uid 1000
[+3.05s] DEBUG: Restoring privileges
[+3.08s] DEBUG: Dropping privileges to uid 1000
[+3.08s] DEBUG: Writing /home/xbmc/.dmrc
[+3.08s] DEBUG: Restoring privileges
[+3.09s] DEBUG: Starting session XBMC as user xbmc
[+3.09s] DEBUG: Session 1556 running command /usr/sbin/lightdm-session xbmc-standalone
[+3.16s] DEBUG: New display ready, switching to it
[+3.16s] DEBUG: Activating VT 7
[+3.16s] DEBUG: Registering session with bus path /org/freedesktop/DisplayManager/Session0
[+3.16s] DEBUG: Session 1556 exited with return value 1
[+3.16s] DEBUG: User session quit
[+3.16s] DEBUG: Stopping display
[+3.16s] DEBUG: Sending signal 15 to process 1248
[+3.59s] DEBUG: Process 1248 exited with return value 0
[+3.59s] DEBUG: X server stopped
[+3.59s] DEBUG: Removing X server authority /var/run/lightdm/root/:0
[+3.59s] DEBUG: Releasing VT 7
[+3.59s] DEBUG: Display server stopped
[+3.59s] DEBUG: Display stopped
[+3.59s] DEBUG: Active display stopped, switching to greeter
[+3.59s] DEBUG: Switching to greeter
[+3.59s] DEBUG: Starting new display for greeter
[+3.59s] DEBUG: Starting local X display
[+3.59s] DEBUG: Using VT 7
[+3.59s] DEBUG: Logging to /var/log/lightdm/x-0.log
[+3.59s] DEBUG: Writing X server authority to /var/run/lightdm/root/:0
[+3.59s] DEBUG: Launching X Server
[+3.59s] DEBUG: Launching process 1669: /usr/bin/X :0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+3.59s] DEBUG: Waiting for ready signal from X server :0
[+6.10s] DEBUG: Got signal 10 from process 1669
[+6.10s] DEBUG: Got signal from X server :0
[+6.10s] DEBUG: Connecting to XServer :0
[+6.11s] DEBUG: Starting greeter
[+6.11s] DEBUG: Started session 1677 with service 'lightdm', username 'lightdm'
[+6.18s] DEBUG: Session 1677 authentication complete with return value 0: Success
[+6.18s] DEBUG: Greeter authorized
[+6.18s] DEBUG: Logging to /var/log/lightdm/x-0-greeter.log
[+6.18s] DEBUG: Session 1677 running command /usr/lib/lightdm/lightdm-greeter-session /usr/sbin/lightdm-gtk-greeter
[+6.27s] DEBUG: Greeter connected version=1.2.1
[+6.27s] DEBUG: Greeter connected, display is ready
[+6.27s] DEBUG: New display ready, switching to it
[+6.27s] DEBUG: Activating VT 7
[+6.27s] DEBUG: Stopping greeter display being switched from
[+6.62s] DEBUG: Greeter start authentication for xbmc
[+6.62s] DEBUG: Started session 1794 with service 'lightdm', username 'xbmc'
[+6.69s] DEBUG: Session 1794 got 1 message(s) from PAM
[+6.69s] DEBUG: Prompt greeter with 1 message(s)
