All,
Today I made an error log for an othe rissue what I have with an app. So I thought let me try to investigate my audio drop problem with bitstream.
So I turned on a movie with bitstream and let it run. At the moment I investigated the drop I uploaded the log:
http://xbmclogs.com/show.php?id=24344
As you see there are a lot of broken pipes with audio engine with causes my sound to stotter (hope the word is known in english). However since I already tested many things I would like to ask you guys to investigate this.
I made my research for my part in this topic:
http://forum.xbmc.org/showthread.php?tid=149221&page=2
Things I changed to make sure it works:
- NFS for 50 megabyte per second
- Tested an alternative switch
- Tested with wireshark (positive test, no problems)
- Changed from app, since the originall app is not working properly
But this error I cannot solve on my own.
Any additional info needed, let me know.
Don't post in development section
Moving again to Linux section - there's many good ALSA config guys there. Would also suggest you post your alsa aplay settings and give more details,
My error is concerning the:
ERROR: CAESinkALSA::HandleError(snd_pcm_avail) - underrun
This is the only thing I can trace back which may cause my audio drops during bitstream movies.
The debug log from XBMC:
12:50:41 T:140144605599488 DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:11613647.625556, should be:11689833.333333, error:76185.707778
12:50:41 T:140145396582144 DEBUG: webserver: request received for /image/image://http%253a%252f%252fcf2.imgobject.com%252ft%252fp%252foriginal%252fs2IG9qXfhJYxIttKyroYFBsHwzQ.jpg/
12:50:41 T:140145387054848 INFO: CAESinkALSA - ALSA: pcm_hw.c:535:(snd_pcm_hw_hwsync) SNDRV_PCM_IOCTL_HWSYNC failed (-32): Broken pipe
12:50:41 T:140145387054848 ERROR: CAESinkALSA::HandleError(snd_pcm_avail) - underrun
12:50:41 T:140144605599488 INFO: CAESinkALSA - ALSA: pcm_hw.c:517:(snd_pcm_hw_delay) SNDRV_PCM_IOCTL_DELAY failed (-32): Broken pipe
12:50:42 T:140144605599488 INFO: Previous line repeats 11 times.
12:50:42 T:140144605599488 DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:12305924.906333, should be:12189833.333333, error:-116091.573000
12:50:42 T:140145396582144 DEBUG: webserver: request received for /image/image://http%253a%252f%252fcf2.imgobject.com%252ft%252fp%252foriginal%252fs2IG9qXfhJYxIttKyroYFBsHwzQ.jpg/
12:50:44 T:140144605599488 DEBUG: CDVDPlayerAudio:: Discontinuity2 - was:14190194.444333, should be:14138922.963286, error:-51271.481048
My
/etc/asound-pulse.conf
# PulseAudio plugin configuration
pcm.!default {
type pulse
hint {
show on
description "Default ALSA Output (currently PulseAudio Sound Server)"
fallback "sysdefault"
ctl.!default {
type pulse
My:
/etc/alsa-pulse.conf
@hooks [
func load
files [
"/etc/asound.conf"
"/etc/asound-pulse.conf"
"~/.asoundrc"
errors false
<confdir:alsa.conf>
My:
/usr/share/alsa/smixer.conf
_full smixer-python.so
usb {
searchl "USB"
lib smixer-usb.so
ac97 {
searchl "AC97a:"
lib smixer-ac97.so
hda {
searchl "HDA:"
lib smixer-hda.so
My:
/usr/share/alsa/alsa.conf
http://pastebin.com/qPE81CZw
Did not fit in a forum message
If an other log or piece of info is needed let me know.
Config:
- Opensuse 12.2 64 bit
- Sapphire Edge HD2 (Atom D525 & ION2)
pulse just doesn't work properly with Xbmc atm. Imho it introduces too much audio lag and thats why you see underruns.
But I compiled xbmc with the:
./bootstrap;
./configure --prefix=/usr --enable-vdpau --disable-pulse --disable-crystalhd
make -j4
The reason I coppied the logs is because I had no clue what logs are needed. This is somewhat new terrain for me so just ask and I will answer if something is missing. Maybe even something above is incorrect or is using pulse, I have no clue
You may have compiled xbmc without pulse, but the config files are still there and pulseaudio is still there too I bet.
rename all those config files and purge pulseaudio and alsa-plugins then reinstall alsa-tools and libasound2.
sudo apt-get remove --purge pulseaudio alsa-plugins -y
sudo apt-get install --reinstall alsa-tools libasound2
sudo restart xbmc
alsamixer
Reconfigure your xbmc audio settings and post a screenshot of that.
Would like a screenshot of alsamixer with F6 pressed.
uNi
Just for my info:
With that I should also eliminate my KDE desktop if I am correct!
So in short based on you wow pulse might influence the alsa setup in such a way that xbmc goes nuts?
Furthermore it is not an issue to get rid of KDE, but just want to be sure.
Btw I am using OpenSuSe so no apt-get, but I will manage.
With full desktop pulseaudio is required, though I have no idea about desktop installs or how-to resolve those.
You could have already provided basic information such as that, either way pulseaudio is evil imo.
Given that new information I defer to other peoples knowledge as mine is insufficient.
uNi
@Uni: No I would welcome your help very much, since I actually only use XBMC on the HTPC I can deinstall the desktop environment. Takes only a little longer to figure. This afternoon I am away for the weekend but will try to configure remote and then I can test on monday.
at least on unity(and probably most other desktops) pulse is not strictly required. removing it will not remove the entired desktop environment (only the ubuntu-desktop meta package).
edit: plz also note the running xbmc on top of a compositing window manger like compiz in unity (and Kwin with compositing ON) usually does not work very well.
Complete KDE deinstalled.
Complete pulse removed except 2 components I could not get rid of:
- libpulse0
- libpulsemainloop-glib0
Furthermore reinstalled the packages requested:
htpc01:~ # zypper in -f alsa-tools libasound2
Loading repository data...
Reading installed packages...
Forcing installation of 'alsa-tools-1.0.26.1-42.1.x86_64' from repository 'Multimedia Build 12.2'.
Forcing installation of 'libasound2-1.0.26-131.1.x86_64' from repository 'Multimedia Build 12.2'.
Resolving package dependencies...
The following NEW packages are going to be installed:
alsa-firmware alsa-tools fxload
The following package is going to be reinstalled:
libasound2
3 new packages to install, 1 to reinstall.
Overall download size: 2.6 MiB. After the operation, additional 9.2 MiB will be used.
Continue? [y/n/?] (y): y
Retrieving package alsa-firmware-1.0.25-20.1.noarch (1/4), 2.1 MiB ( 8.6 MiB unpacked)
Retrieving: alsa-firmware-1.0.25-20.1.noarch.rpm ..........................................................................................[done (3.1 MiB/s)]
Retrieving package libasound2-1.0.26-131.1.x86_64 (2/4), 323.8 KiB ( 1.0 MiB unpacked)
Retrieving: libasound2-1.0.26-131.1.x86_64.rpm ........................................................................................................[done]
Retrieving package fxload-2008_10_13-18.1.4.x86_64 (3/4), 23.6 KiB ( 45.1 KiB unpacked)
Retrieving: fxload-2008_10_13-18.1.4.x86_64.rpm .......................................................................................................[done]
Retrieving package alsa-tools-1.0.26.1-42.1.x86_64 (4/4), 168.4 KiB (551.7 KiB unpacked)
Retrieving: alsa-tools-1.0.26.1-42.1.x86_64.rpm .......................................................................................................[done]
Installing: alsa-firmware-1.0.25-20.1 .................................................................................................................[done]
Installing: libasound2-1.0.26-131.1 ...................................................................................................................[done]
Installing: fxload-2008_10_13-18.1.4 ..................................................................................................................[done]
Installing: alsa-tools-1.0.26.1-42.1 ..................................................................................................................[done]
Now I am going to update xbmc to the latest GIT.
er I may have got carried away, was it alsa-utils that needed installing as opposed of alsa-tools? I always confuse those two. Yea its alsa-utils my bad.
uNi
No problem
As long as the 2 remaining pulse packages do not cause any problem1
htpc01:~/XBMC/xbmc # zypper in -f alsa-utils
Forcing installation of 'alsa-utils-1.0.26-75.1.x86_64' from repository 'Multimedia Build 12.2'.
alsa-utils
1 package to reinstall.
Overall download size: 963.3 KiB. No additional space will be used or freed after the operation.
Retrieving package alsa-utils-1.0.26-75.1.x86_64 (1/1), 963.3 KiB ( 1.9 MiB unpacked)
Retrieving: alsa-utils-1.0.26-75.1.x86_64.rpm ............................................................................................[done (22.8 KiB/s)]
Installing: alsa-utils-1.0.26-75.1 ....................................................................................................................[done]
