2012-12-27, 15:14
Alright.
Ive got a bit of an issue:
My hardware/software:
Win 8 x64
C2D E8400
AMD Radeon 6850 HD
Asus MB
Yamaha A1000 AVR
Samsung Plasma TV all via HDMI
The problem is that this happens at random, sometimes when I start XBMC it can't enable exclusive mode on WASAPI so I get stuttering video. A hard reset of my HTPC fixes this, and then it is OK again. The thing is it doesn't do this every time I restart XBMC and the driver versions have been constant throughout my testing and it has worked so I am not sure what is going on.
The only thing I can think off, I also run foobar /w WASAPI plugin in the background, but out to a USB DAC, and not via HDMI. Since they are separate playback devices there shouldn't be an issue with them each running in exclusive mode. And it has worked with this still running in the background.
Sometimes, but not every time, if I find I have stuttering video, I can go to audio settings enable DirectSound mode on AMD HDMI and renable WASAPI and it will fix it, but sometimes, I have to do a hard reset
Win 8 x64
C2D E8400
AMD Radeon 6850 HD
Asus MB
Yamaha A1000 AVR
