I configured some FM radio channels in NPVR, it works fine from XBMC but they show up in the TV section instead of the Radio section. Any idea how to avoid this?
Hmm. Sounds like a bug. I'll check it out.
I know DVB radio channels show up in the right place, but I haven't explicitly checked an FM radio channel.
I just tried here, and the FM radio station correctly ended up in the Radio section.
I suspect the problem will fix itself if you install the latest post-2.5.9 patches from:
http://forums.gbpvr.com/showthread.php?5...arted-info
Could you please describe how you did it? In just upgraded to R1.
I am doing:
Devices -> (Hauppauge WinTV-7164 Analog Capture) -> Add FM
(I think that's part of my problem because the dialog says Add FM Station as Channel...)
Yep, that's what I did.
Do you have those NextPVR patches installed? If not, all the radio channels show up as TV channels. That sounds like what you're seeing.
I indeed installed "NPVR 2.5.9 Patches R1" (4 files inside -- any other patch needed?), they still show up in the TV section (Frodo RC2)
Odd. You'll probably need to post the xbmc.log and web.log for me to take a look.
web.log
xbmc.log
The only radio station is "Première Chaîne", all others are TV ATSC channels.
