CASE: Morex 557
CPU: Celeron G540
MOBO: ASRock B75M-ITX LGA 1155
DRIVE: M4 SSD
FANS: Couple 40mm fans
Anyone know what would suffice for a PicoPSU? It's very confusing.
Also in the market for low profile CPU cooler!
Thank you!
I like the 90W power brick, unlike this which I almost bought.
www.amazon.com/gp/product/B00316T5S8/
Probably doesn't really make much of a difference though.
PicoPSUs aren't too hard to buy, but finding the right power brick is a nightmare. Based off that jonnyguru article, the power brick you choose is a big deal for optimum performance.
I love how the Shuriken engulfs the ITX board, but I'm not sure it will fit in the Morex 557. I hear excellent things about the
http://www.amazon.com/Dynatron-T459-Profile-Active-LGA1156/dp/B006V5SZMI so I will probably go with this. It is just a Celeron after all and I think any low profile fan that fits and is quiet will be enough. Only $30 as well.
Thanks a lot for your input!
