Across all add-ons vidbux and vidxden return script errors. This has been the case for about two week now. Is there a setting that can be changed or are their servers down?
I'm on Eden with an ATV2.
Thank you!
Both sources now require captcha's for their streams, which breaks their usage in XBMC. Since this change was made on their end, there's nothing you can presently do to fix it within XBMC.
There are a few people working on it from what I've heard.
Any update on if these sources are working or can be fixed for the atv2?
these links are useless for me is it the same for everyone or just me and also is there a fix its getting annoying
A fix for where exactly, which addons?
We pushed updates in for Urlresolver quite some time ago, so any addons using it will benefit
for showing captchas on appletv2 they never show up for me just says this site requests a captcha
same here, it keeps asking for the captchas and the link then errors out
