Full Version: Recording problem
Pages: 1 2 3
I have got the (I think) same issue as you. My system is XBMC 14.0-ALPHA1 64bit, HTS Tvheadend 3.2, Tvheadend HTSP Client 1.9.27 on gentoo. I get the same error "could not add dvrEntry" on xbmc version 13 too so I dont think this is a v14 issue only.
the log:
07:56:54 T:140432313722816   DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0
07:56:54 T:140432313722816   DEBUG: OnKey: return (0xf00d) pressed, action is Select
07:56:54 T:140430765868800   DEBUG: AddOnLog: Tvheadend HTSP Client: AddTimer - channelUid=3 title=Disco epgid=24929
07:56:54 T:140430765868800   DEBUG: AddOnLog: Tvheadend HTSP Client: GetBackendTime - tvheadend reported time=1403416614, timezone=-60, correction=-514289056
07:56:54 T:140430765868800   ERROR: AddOnLog: Tvheadend HTSP Client: ReadResult - command failed - Could not add dvrEntry
07:56:54 T:140430765868800   DEBUG: CAddonCallbacksAddon - QueueNotification - Tvheadend HTSP Client - Error Message : 'Command failed: Could not add dvrEntry'
07:56:54 T:140430765868800   DEBUG: AddOnLog: Tvheadend HTSP Client: AddTimer - Failed to get addDvrEntry
07:56:54 T:140430765868800   ERROR: PVR - AddTimer - addon 'HTS Tvheadend:127.0.0.1:9982' returned an error: rejected by the backend
07:56:54 T:140430765868800   ERROR: PVR - AddTimer - cannot add timer to client '1': rejected by the backend
07:56:54 T:140432313722816   DEBUG: ------ Window Init (DialogKaiToast.xml) ------
07:56:54 T:140432313722816   DEBUG: ------ Window Init (DialogOK.xml) ------
07:56:54 T:140432313722816    INFO: Loading skin file: DialogOK.xml, load type: KEEP_IN_MEMORY
07:56:54 T:140430749083392 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
07:56:54 T:140431716484864   DEBUG: Thread JobWorker 140431716484864 terminating (autodelete)
07:56:55 T:140430757476096 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
07:56:56 T:140430757476096    INFO: CDVDPlayerVideo - Stillframe detected, switching to forced 25.000000 fps
07:56:56 T:140430757476096   DEBUG: CPullupCorrection: pattern lost on diff 200000.000000
07:56:57 T:140432313722816   DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
07:56:58 T:140432313722816   DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0
07:56:58 T:140432313722816   DEBUG: OnKey: return (0xf00d) pressed, action is Select
07:56:58 T:140432313722816   DEBUG: ------ Window Deinit (DialogOK.xml) ------
07:56:58 T:140430765868800   ERROR: PVRTimers - InstantTimer - unable to add an instant timer on the client
07:56:58 T:140432313722816   DEBUG: ------ Window Init (DialogOK.xml) ------
07:57:00 T:140430757476096   DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00, frameduration: 40000.000000
07:57:00 T:140432313722816   DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0
07:57:00 T:140432313722816   DEBUG: OnKey: return (0xf00d) pressed, action is Select
07:57:01 T:140432313722816   DEBUG: ------ Window Deinit (DialogOK.xml) ------
07:57:01 T:140430765868800   DEBUG: video stream stalled. start buffering
07:57:01 T:140430765868800   DEBUG: CDVDPlayer::SetCaching - caching state 2
I will try to rebuild the pvr addon. Can someone please provide a git url for the proper pvr-hts-addon?
You're using tvheadend 3.2 and this is a post from nearly a year and a half ago!
Update to 3.9.xxx and see if resolved.
Pages: 1 2 3
