2012-12-30, 04:12
Hi all
I recently dug up my old Acer Revo 3600 again and installed XBMCbuntu 12.0-RC2. It all ran perfectly, also surviving reboots, but today I started up the Revo and XBMC wouldn't start. I pasted the crash log here (http://pastebin.com/3UQngxFy ). Just a snippet (to aid forum indexing/searching) below.
The last things I remember doing last night before shutting down were:
I have removed all new themes and addons from ~/.xbmc/addons to no avail. I am not exactly sure how I'd go about removing the Music source, but I doubt that's the problem?
On a side note: On the Ubuntu login screen, I changed my login shell from XBMC to XBMbuntu (expecting to get a default ubuntu gnome environment). I can log in, but then all I get is the XBMCbuntu wallpaper, and a fast blinking grey half-inch line at the bottom (photo further down - hey, took me 20 attempts to catch the time the line would blink ;-)
Any other information which might be relevant, let me know and I'll post that too.
Screen photo of default ubuntu login:
- Installed new themes
- Installed some addons
- Added a new source for Music (until then, I only scanned my movies and TV shows)
############### STACK TRACE #################
=====> Core file: /home/ssuter/core (2012-12-29 18:54:22.475380813 -0700)
[New LWP 4719]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/i386-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/xbmc/xbmc.bin'.
Program terminated with signal 6, Aborted.
#0 0xb772d424 in __kernel_vsyscall ()
Thread 1 (Thread 0xb33fd740 (LWP 4719)):
#1 0xb5c971df in raise () from /lib/i386-linux-gnu/libc.so.6
#2 0xb5c9a825 in abort () from /lib/i386-linux-gnu/libc.so.6
#3 0xb5cd439a in ?? () from /lib/i386-linux-gnu/libc.so.6
#4 0xb5cdeee2 in ?? () from /lib/i386-linux-gnu/libc.so.6
#5 0xb619487d in snd_config_substitute () from /usr/lib/i386-linux-gnu/libasound.so.2
#6 0xb6196345 in ?? () from /usr/lib/i386-linux-gnu/libasound.so.2
#7 0xb6196fae in snd_config_update_r () from /usr/lib/i386-linux-gnu/libasound.so.2
#8 0xb61974f8 in snd_config_update () from /usr/lib/i386-linux-gnu/libasound.so.2
#9 0x08762251 in CAESinkALSA::EnumerateDevicesEx(std::vector<CAEDeviceInfo, std::allocator<CAEDeviceInfo> >&) ()
#10 0x0874d171 in CAESinkFactory::EnumerateEx(std::vector<AESinkInfo, std::allocator<AESinkInfo> >&) ()
#11 0x087534e8 in CSoftAE::CSoftAE() ()
#12 0x0874bb95 in CAEFactory::LoadEngine(AEEngine) ()
#13 0x0874bd1c in CAEFactory::LoadEngine() ()
#14 0x08b3c184 in CApplication::Create() ()
#15 0x08bd922b in XBMC_Run ()
#16 0x083096c3 in main ()
############# END STACK TRACE ###############
