2012-12-30, 16:00
Hello Guys!
Windows 8 X64
XMBC Frodo 12 RC2 Nightly Builds
Hardware:
ZBOX nano XS AD11 Plus
4GB RAM
64 GB SSD
2TB UDB HDD
AMD E-450 APU Radeon™ HD 6320
Celine Dion Live in Las Vegas Dolby TRUE-HD stuttering (playing from USB and NAS)!
I ripped the Blueray with Make MKV like all other Bluerays!
All other MKVs including DTS-HDMASTER & Dolby TRUE-HD running smooth!
Any Ideas?
File Info:
Video
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Duration : 1h 33mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Language : English
Default : No
Forced : No
Audio
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 1h 33mn
Bit rate mode : Variable
Maximum bit rate : 9 702 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 96.0 KHz
Bit depth : 24 bits
Compression mode : Lossless
Title : 5.1
Language : English
Default : Yes
Forced : No
Windows 8 X64
Hardware:
4GB RAM
64 GB SSD
2TB UDB HDD
Any Ideas?
File Info:
Video
Format : VC-1
Duration : 1h 33mn
Bit depth : 8 bits
Language : English
Default : No
Forced : No
Audio
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 1h 33mn
Bit depth : 24 bits
Title : 5.1
Language : English
Default : Yes
Forced : No
