(2013-04-11, 09:33)aisman Wrote: [ -> ]Ok may be its my mistake. I'll try to build it on other ffmpeg.
Maybe i didn't copied all the needed files, i'll try again.
I did noticed libavcodec.so.
54 (and others) were already on my system but then as libavcodec.so.
52 version unknown
DS211> ffmpeg
ffmpeg version UNKNOWN, Copyright (c) 2000-2011 the FFmpeg developers
built on Feb 8 2013 20:32:15 with gcc 4.2.1
configuration: --arch=arm --target-os=linux --cross-prefix=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi- --enable-cross-compile --enable-optimizations --disable-yasm --disable-altivec --enable-pic --enable-shared --disable-static --disable-swscale-alpha --disable-ffserver --disable-ffplay --enable-libmp3lame --enable-libfaac --enable-nonfree --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-decoder=amrnb --cc=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-ccache-gcc
libavutil 50. 40. 1 / 50. 40. 1
libavcodec 52.120. 0 / 52.120. 0
libavformat 52.108. 0 / 52.108. 0
libavdevice 52. 4. 0 / 52. 4. 0
libavfilter 1. 77. 0 / 1. 77. 0
libswscale 0. 14. 0 / 0. 14. 0
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
DS211>
Maybe build it against lower version ?
i think you have to install ffmpeg (bin too) which i sent you
Finally got it up and running but have a few questions.
1 What settings are needed to make it 100% work with XBMC?
Currently i have set
output_edl=1
mkv_time_offset=0.0 (from what i have read it should be fixed?)
The rest is all default. Do i need anything more?
2 How do you users handle recordings which already start with a commercial? My idea was to configure TVH in such a way it would start recording on program before actual wanted program so it at least detects a logo.
3 What is need (config?) to start comskip directly when recording starts, live_tv=1 ?
schumi2004
I'm on dsm 4.2, could you please post how to?
Or do you know if this will make it to the synocommunity repository?
(2013-04-14, 11:27)pvautrin Wrote: [ -> ]@schumi2004
Don't think this will make it to synocommunity but afterwards it was actually easy to get it running on my Synology with the files from
aisman.
Updated instructions:
http://forum.xbmc.org/showthread.php?tid...pid1400001
In fact, bootstrap is not necessary. Just need to put files strictly following the directory tree and reboot. I run it on the NAS with no bootstrap. I put the files in /usr/bin ; /usr/share ; /etc and /lib. Include folder should be put in /usr.
Anyone tried to re-use a logo file?
I'm trying to save some time by re-using generated logo file but comskip gives an error message.
Something like this comskip videofile.mkv --logo=logo.txt
terminate called after throwing an instance of 'std::out_of_range'
what(): x exceeds max width
Aborted (core dumped)
(2013-04-14, 14:04)aisman Wrote: [ -> ]In fact, bootstrap is not necessary. Just need to put files strictly following the directory tree and reboot. I run it on the NAS with no bootstrap. I put the files in /usr/bin ; /usr/share ; /etc and /lib. Include folder should be put in /usr.
Use this method for having post-processing work successfully!
My method brakes post-processing for some reason.
(2013-04-17, 23:21)schumi2004 Wrote: [ -> ] (2013-04-14, 14:04)aisman Wrote: [ -> ]In fact, bootstrap is not necessary. Just need to put files strictly following the directory tree and reboot. I run it on the NAS with no bootstrap. I put the files in /usr/bin ; /usr/share ; /etc and /lib. Include folder should be put in /usr.
Ok, ty. Maybe you share your settings, it is desirable to step-by-step, and if you can, then attach the script to the post processing on nas NAS Synology with tvheadend.
(2013-04-18, 10:02)aisman Wrote: [ -> ]Ok, ty. Maybe you share your settings, it is desirable to step-by-step, and if you can, then attach the script to the post processing on nas NAS Synology with tvheadend.
Instructions:
Extract
these files and place them in corresponding directories
Quote:/usr/bin
/usr/share
/etc
/lib
Then i did chmod +x and chmod 777 on these files
Quote:/usr/bin/comskip, ffmpeg, ffprobe
Created a backup from original comskip.ini in /etc/comskip/ and replaced content van original with this:
Note: Maybe someone has a better version and would like to share it with some explananation if possible?
http://pastebin.com/K4G55Umn
16-03-2014: Updated version
http://pastebin.com/ExhsYNsq
Useful information
http://www.kaashoek.com/files/tuning.htm
Created a folder for scripts, for example /volume1/@appstore/scripts, and placed this processing in it.
comskip-pp.sh
Note: Change COMSKIPLOGS and TVHEADENDPP to fit your needs.
Note: I also removed MKV and TS selection as seen in processing script in startpost because i only use MKV to store my recordings.
http://pastebin.com/1LKY3JEC
07-05-2014: Updated version
http://pastebin.com/mzkxtTk6
Added this processing line in TVHeadend in recording configuration
Quote:/volume1/@appstore/scripts/comskip-pp.sh %f
That's it.
Only a few things i would like to solve so maybe someone can help me with that.
Currently comskip detects and removes commercials but i think it's based on volume difference only. What i would like to see is remove every frame without channel logo!!
Sometimes the channels i watch are having a sort of commercial or program announcement before the actual program (same volume level but without channel logo!), i was hoping you could skip that as well?
Second things is trying to re-use channel logo, currently comskip crashes when doing that.
cbxbiker61 or any one else.
Are you guys successful in reusing logo and/or logo detection only (2) ?
When running same recording on a windows machine i'm getting a totally different logo then with Linux version and i can re-use it.
In both situations the edl output is the same using same comskip.ini.
(2013-04-24, 19:47)schumi2004 Wrote: [ -> ]@cbxbiker61 or any one else.
Logo files are just an approximation of the logo, kind of a "best-guess" at the logo, so logo files created on different versions almost certainly will not match the logo file of another version. The software uses "fuzzy" logic when it matches logos.
When i re-use the logo created with Linux version comskip generates a error.
When i do the same on Windows with the Windows logo file created no problem.
I'm not switching them between versions.
Edit:
DS211> comskip /volume1/recordings/Goede-tijden,-slechte-tijden/RTL-4-Goede-tijden,-slechte-tijden.2013-04-30.20-00.mkv --logo=/volumeUSB1/usbshare/logs/coms
kip/RTL-4-Goede-tijden,-slechte-tijden.2013-04-30.20-00.logo.txt
Comskip 0.93b.000, made using avcodec
The commandline used was:
comskip /volume1/recordings/Goede-tijden,-slechte-tijden/RTL-4-Goede-tijden,-slechte-tijden.2013-04-30.20-00.mkv --logo=/volumeUSB1/usbshare/logs/comskip/RTL-4-Goede-tijden,-slechte-tijden.2013-04-30.20-00.logo.txt
Setting logo file to /volumeUSB1/usbshare/logs/comskip/RTL-4-Goede-tijden,-slechte-tijden.2013-04-30.20-00.logo.txt as per commandline
No INI file found in current directory. Searching PATH...
INI file found at /etc/comskip/comskip.ini
Using /etc/comskip/comskip.ini for initiation values.
DS211>
Maybe some incorrect setting in comskip.ini ?
