Full Version: [MOD] Re-Colored Default Icons (Updated)
Pages: 1 2
UPDATE: Updated all icon links to latest GIT, all missing icons added (33 more icons in each set) 2-22-13
Hello, not sure how useful people will find this but myself, I use a purple color set in Aeon Nox, so I recolored the default icons. I use the below settings in the main menu window, and I reverse those two colors for all the other windows:
So here are re-colored purple icons to fit the setup above, I also included a purple cursor.
Backup the images if you dont like them, copy over media folder.
Updated: 2-22-13
If you like them but prefer a different color, let me know and I'll make them when I have time.
Be aware that these will only work with the nightly 'GIT' version of Aeon Nox and probably not with the official version when released as the images will probably be in the textures.xbt
UPDATE: Thanks to CutSickAss, they are packed up in theme .xbt files, you can find them in post #10 below, this means you will be able to use them with the default theme when the official version of Aeon Nox comes out Smile
Thanks CutSickAss!
Here is a example of how they look in XBMC with the color setup I use.
Red Icons:
Updated: 2-22-13
Yellow:
Updated: 2-22-13
Green:
Updated: 2-22-13
Dark Blue:
Updated 2-22-13
Orange:
Updated: 2-22-13
Pink:
Updated: 2-22-13
Cool thanks, using the green icons
I took the liberty of using TexturePacker in order to create individual .xbt files for each of the icons pack. This way, if you place them in the "skin.aeon.nox\media" folder, and select the corresponding theme from within XBMC (System -> Appearance -> Skin -> Theme), you'll have the default theme, together with the colored icons.
I've uploaded them here:
Icons_Blue
Icons_Green
Icons_Orange
Icons_Pink
Icons_Purple
Icons_Red
Icons_Yellow
Cool thanks!!
I had no idea you could do that Smile
EDIT: I updated the first post to point to your files Smile
...and i added it to the [EXTRAS] section. thx for this.
@ phil: the same with alpha and colordiffuse, that's possible with a workaround?
(2013-01-01, 14:42)fmronan Wrote: [ -> ]@ phil: the same with alpha and colordiffuse, that's possible with a workaround?
not in a nice way.
colordiffuse with fallback in Xbmc 13, that's the good way perhaps
Pages: 1 2
