Thats just the .img. Do I need anymore of the files from the zip?
mike77
Seems u like my dropboxfiles
Biatsch
Your dropbox is a veritable treasure trove, but it would be nice if you'd document the contents in a readme file!
Since you seem to have done the most testing on these boxes, may I ask what do you find is the best combination of OS/XBMC to run your ATV1200s?
Is the "oman" XBMC build an improvement on the supplied Frodo or stock Gotham?
I have 2 boxes, both now on the MyGica 4.2 f/w with Gotham 13.0. It seems to be a good combination, but I do get occasional lip synch problems and I am not happy with RF keyboard/mouse performance.
I have tried Concorey's MX Linux with Frodo, which was OK, but my box froze a couple of times overnight and I prefer Gotham. I also need passthrough audio which is not available. Is there a better Linux available for this box?
Any tips appreciated.
Android 4.2 with xbmc gotham nightly is running fast .......
This was my last test for the boxes iam selling them on ebay an ordered 2 beelink s89 8gb..... The xbmc oman is for the beelink just downloaded it [GRINNING FACE WITH SMILING EYES]
So now for the next days iam without a box just waiting impatiently for the new ones .... Wich will arrive in a few weeks [FEARFUL FACE][FEARFUL FACE]
Hope there is fully 1080p support for xbmc saw the settings in a video 😛
I'm not too fussed about true 1080p as my TV is only 37" 720p so this box is adequate for me. I'll stick with Android 4.2 and stock Gotham 13 until maybe Croniccorey release Gotham Linux with passthrough.
Good luck with the new boxes and thanks for all your contributions on the ATV1200!
Hello
Anyone helps me.
I have ATV1200 up to 4.2, but i can't passthrough DTS.
How to play video and passthrough DTS on Android 4.2.2 of ATv1200?
Thank alot
I'm passing through DTS with my atv520 with this firmware (these box share the same board).
Check in the audio config of android passthrough and after that in xbmc, audio setting, advanced, passthrough and MY DECODER CAN DECODE DTS or something similar
Hi am i correct that this new mygica update will work on my geniatech 1200
Hello, first of all I want I apologize for my bad English.
I use Google translate to make it as understandable as possible to make.
I tried to flash the box on Linux, but every time I've been waiting the 10 seconds immediately comes the droid and a loading bar.
After this, the box will reboot and stays in a black screen
Does anyone have an idea where the problem may be?
_________________
daily deals,
online shopping sites,
hot deals,
best deals
