Full Version: Physical Tuners / Recording Priority?
I have successfully made the transition from Windows Media Center (Ever since it began) I have tried so many (in fact all) of the 3rd party alternatives over the years but I now have a (nearly) perfect replacement but as with all changes I have some questions :-)
1, I use the DVBLogic DVBLink PVR and would like to know if it is possible to set a priority for recording at all? for example if a program is set to record and the tuner is in use it just doesn't record :-( (I have just purchased a dual tuner Amiko box to hopefully reduce this from happening)
2, Although I have the DVBLink Tuner working well I am now left with 2X DVB-S2 & 2X DVB-T2 tuners in my Media Center is there a way (simple) that XBMC can use these?
Any advice will be used with appreciation! :-)
