2013-01-02, 21:55
I've reported an issue where XBMC doesn't seem to be correctly picking up the album cover art set in the id3 tags for some of the files in my music library. I wanted to experiment with this a bit to see if I could identify why this works with some files and not others, but I'm running into a new problem, I can't seem to remove my big music library as a media source in Frodo.
Frodo doesn't seem to allow bringing up the context menu from the root menu as described in the wiki post on media sources. I wasn't able to find any way in the GUI to remove a media source. Finally I removed everything in the <music> section of the sources.xml file in my userdata directory, but XBMC is still scanning the directory that I had originally set up as the source for my music media. Here is a snippet from the log:
14:50:50 T:3620 DEBUG: MUSIC_INFO::CMusicInfoScanner:oScan Skipping dir 'Z:\Music\' due to no change
Does anyone know how to definitively remove a media source from the music library? Basically I want to stop scanning Z:\Music.
