2013-01-02, 23:51
I have been using XBMC (Dharma version) for the past two years and up until recently, when mainly the movies scraper started to fail, I was very happy with it.
Given that the developers have made significant steps and FRODO was close to its final release I decided to start the immigration process.
I must admit that it was not an easy, brief or uneventful journey but after a few days, I thought that I had finally have come to a point where I could consider the whole process complete, with the exception of finding – probably later – a suitable Confluence mod or another skin with more options.
Or so I thought….
When I started the immigration process to XBMC FRODO RC2 I copied my videos database to the appropriate folder (I am using the portable mode) and XBMC converted the old library file MyVideos34.db to the new MyVideos75.db file without any problems. Afterwards it re-associated the thumbs.
During this time I had my two NAS boxes turned on (in one I store music and TV series, while the other one is dedicated to movies). When I was almost finished I updated the database without problems. Actually FRODO was able to detect and add content something that for some reason I could no longer do for certain items in Dharma (probably the scraper add-on was outdated).
However the next day (yesterday) I noticed the following:
While having NAS-1 (Music & TV) turned on, I choose to update the database, since I had added some video files.
The scraper was stuck forever on “Preparing..”
I was baffled at first, given that I had never encountered this problem with XBMC Dharma. When I turned on NAS-2 (Movies) the update continued without a problem.
During the years that I have been using XBMC Dharma, if any of my sources were offline during the update XBMC just ignored it and moved on. In this case it would not add anything to the Movies catalog and it would go on to scan for TV content.
Is this no longer the case?
If it is, is there a way to have XBMC ignore/skip a media source when offline and continue to the next, without doing anything (i.e. deleting) to the offline content?
I assume that many users would have some content from an offline source that is occasionally updated and I do not see the point at all for XBMC to wait for this to become available in order to continue the update process.
I would truly appreciate some input from either the developers or fellow users on that issue that is a major problem for me.
Or so I thought….
