Full Version: Issue with resolution after Sleep
When I put the htpc on Sleep, turn the TV and Receiver off. The problem is when I turn everything back on, the resolution of XBMC is messed up.
It either takes the top left quarter of the TV screen or it seems to be zoomed in and I need to quit XBMC in either case and start it again.
Anyone knows what causes that and is there a way to prevent it?
XBMC isn't fantastic at resuming from sleep. Your best bet is to try XBMCLauncher, and set it to close XBMC on sleep and start XBMC on wake.
Thanks both, I'll look into both options.
