General Support
OS independent / Other
> RC updates
Full Version:
RC updates
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
gibbio
2013-01-04, 06:01
Can you update to different RC with in XBMC? Or do you download it from The web? If download from the web does this erase all your settings/addons etc?
phil65
2013-01-04, 06:58
no built-in update support. and no, it doesn´t erase your settings. If you´re updating from Eden or lower i recommend to do a clean install though.
un1versal
2013-01-04, 07:06
Depends on OS, usually just install over the top for Windows, OSX etc,
For Linux you need a PPA, it covered in wiki. see
http://wiki.xbmc.org/index.php?title=XBM...FDebian.3F
and
http://wiki.xbmc.org/index.php?title=XBM...remotes.29
uNi
General Support
> RC updates
