2013-03-31, 15:49
(2013-03-30, 23:41)orehek13 Wrote: [ -> ]Can you explain me pls how get to data, or were can i make this new script?1) you have to root your device (for wm8650 and wm8850, http://nanospic.ro/?p=434)
Tnx
2) create your script put it under root or data... not really important ..
3) change permissions to 777
4) install scriptmanager.apk and choose the script you have created, important.. click on run on "boot" and "su" before saving
I created "txt" file on my PC, renamed to "sh" than copied to "MicroSD".
On my android I have rootbrowser installed, it has root rights and easy can move. rename and change permissions for any file...
