Full Version: Is there any way to change the hotkey for Alt-F4
I've recently started setting up my media center with my emulators and games. For whatever reason, Zsnes runs like a dog on my system, whereas Snes9x runs perfectly. The only downside is that I need to press Alt F4 to exit out of Snes9x when I'm done, that or load up touch mouse and exit through the menu. I'm using a Boxee remote and I want to know if there is a program that will allow me to remap Alt F4 to a different key, maybe a long press on a seldom used symbol? I've tried searching but it's a seemingly tricky thing to search for.
Thanks in advance.
What os are you using? In windows I use event ghost to launch a batch file which kills all the emulators running using taskkill from my harmony remote.
Ahh, that sounds like a good idea. I'm running windows 8. I'll look into eventghost tonight, thanks very much.
