Full Version: Menu on power off Button
Hello,
I use 2 different profiles and I´ve seen, that there should be a power off menu to select between change profile and power off xbmc. But if I click the power off button xbmc shut down without any menu.
I´ve got a atv2 with frodo rc3 and a not modded confluence skin.
Are you using the "Power" icon on the lower-left of the display? If so, that should display the Shutdown menu with various options. Don't know if this behaves differently for an ATV2 or not, since I don't own one.
yes this icon did I use...
