Hi!
When I play a xvid with 23.976 fps, the video runs in slow motion.
Audio has normal speed. None of the solutions I found did any
change.
Can you post the mediainfo of the file. We don't currently support files with incorrect framerate reported in the avi container (compared the timestamps of frames).
This shows up in mediainfo as something like:
Frame rate : 25.000 fps
Original frame rate : 23.976 fps
You can remux the files to fix it or wait and see if we can fix it..
It seems not to be the framerate. Seems to be the
low resolution. Other files with 25 fps and a resolution
lower than 480p are running slow, too.
BTW: Is the installation of the omxplayer package necessary,
or does XMBC ship with it? I am not sure, if the omxplayer in
the XBMC sourcetree is only a driver, or the whole player.
At the moment I have the omxplayer package installed.
What distribution and what version of the distribution are you running?
Can you post mediainfo of file.
i think have the same problem with some videos of 23.976 fps, on this videos audio go outsync but on other videos with 25 fps works fine.
its possible to play this files without recode or edit file by file? because i have more than 100 files with this problem
format : AVI
Format/Info : Audio Video Interleave
File size : 269 MiB
Duration : 19mn 53s
Overall bit rate : 1 893 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 19mn 53s
Bit rate : 1 723 Kbps
Width : 704 pixels
Height : 396 pixels
Display aspect ratio : 16:9
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.247
Stream size : 245 MiB (91%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 19mn 53s
Bit rate mode : Constant
Bit rate : 160 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 22.8 MiB (8%)
Alignment : Aligned on interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 504 ms
As I said before
Quote:You can remux the files to fix it or wait and see if we can fix it...
(I'm testing a fix, so hopefully the wait won't be long)
(2013-01-09, 18:36)popcornmix Wrote: [ -> ]As I said before
Fantastic, im wating you fix ! thanks
(2013-01-10, 15:26)rbej Wrote: [ -> ] (2013-01-09, 20:52)pepi0 Wrote: [ -> ] (2013-01-09, 18:36)popcornmix Wrote: [ -> ]As I said before
Try this:
http://forum.xbmc.org/showthread.php?tid...pid1293361
Hi, thanks for your information, this is only for OpenElec yep? i use Raspbmc, maybe i need to contact person of dev.team of Raspbmc?
