Hello KenV99,
I'm running Openelec/Kodi on a Intel-NUC with USB-HDDs and think about mirroring/backup my music-data to my NAS.
Your addon seems to me the best tool available for this, but I'm new to Kodi and an absolute python-noob...
So I need some 'kickoff'.
My 1st idea is:
1. If Kodi starts - send a WOL to the NAS (afaik is a function in Kodi)
2. when ready start rsync (client on Kodi, is already installed, server runs on the NAS)
- this should be packed into an shell-script.
Do you think I can get this 'wrapped' into your addon?
And, if yes, will this (as long as its running) prevent Kodi from shutting down if no other action takes place?
( I adjusted Kodi to shutdown after the max. possible 120 min.)
I'm not sure how to mix shell, python and this WOL-call.
If you can point me to some further reading...
(2015-03-28, 14:26)wolfn48 Wrote: [ -> ]Hello KenV99,
My 1st idea is:
This is done directly in Kodi, not through this addon:
Wake_on_lan (wiki)
(2015-03-28, 14:26)wolfn48 Wrote: [ -> ]2. when ready start rsync (client on Kodi, is already installed, server runs on the NAS)
I don't know much about rsync. Unless you can set a long timeout, you will need to find a way to poll to see when the NAS is online in your shell script before you start the sync process.
(2015-03-28, 14:26)wolfn48 Wrote: [ -> ]Do you think I can get this 'wrapped' into your addon?
I doesn't need to be 'wrapped' as best as I can tell. Kodi will do the WOL. You will need to write the shell script and link it to the 'on Startup Event' as a shell executable.
There is no way to abort a Kodi shutdown - scripts are terminated automatically if they do not abort themselves in 5 seconds after shutdown starts. However, since the script executes in a subprocess call, it will likely run until it finishes, but it
may cause issues when you retry to restart Kodi because the process may not terminate gracefully. I know this happens in windows, I'm not sure if it happens in Linux.
Thank you very much KenV99,
just played around with your addon + found I can call 1x python OR 1x shell OR 1x call to Kodi.
So I will try to write a little python-script to 1st call Kodi for WOL to my NAS, then do some pings for waiting til ready and then start the rsync.
Found in the Kodi-wiki some links for get me going in python, will give it a try...
Thanks again, will report success or problems...
If you want to code sending the WOL magic packet yourself, more power to you, but if you enable it as above and edit the xml, you may be fine. Or you can use the advanced version:
Add-on:Advanced_Wake_On_Lan (wiki)
I don't see a direct way of calling the kodi wol routines from python or via json, so you will have to either do it from the shell or download the advanced wol add on and look at how it's coded.
Hi KenV99,
Advanced_WOL ist already installed and used by Kodi on my NUC - this way the idea with rsync is born...
But just this moment I found the ethtool in Openelec, has a switch for WOL.
Edit: Bad, only for setting the local port. - Searching continues.
Edit2: Just found this:
#!/usr/bin/env python
import socket
s=socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s.setsockopt(socket.SOL_SOCKET, socket.SO_BROADCAST, 1)
s.sendto('\xff'*6+'\xQQ\xQQ\xQQ\xQQ\xQQ\xQQ'*16, ("255.255.255.255",9))
- It works perfectly!!!
If this works for me, then most problems have gone. Then I will write some shell-code for this job.
(looked into Python-doc -- puuuhh, some overkill I think)
Hi
I've been trying to use KenV99's callback script to run .bat commands that i've made to control my lights , as seen here
http://lightwaverfcommunity.org.uk/forum...e-control/
I have tried to get kodi to plain trigger the .bat which results in a fail
I have tried to get kodi to trigger a .py that triggers the .bat which results in a classic Python script error
I have made a .exe that is the .bat , it works fine when run from the desktop , but Kodi brings up the error 'it is not a recognized internal or external command."
Any solutions or ideas ? The .exe , .bat and .py all run and work themselves , just not when triggered.
General xbmc log :
19:11:48 T:1844 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:11:48 T:1844 NOTICE: -----------------------------------------------------------------------
19:11:48 T:1844 NOTICE: Starting Kodi (14.2-RC1 Git:20150311-e7ba06f). Platform: Windows NT x86 32-bit
19:11:48 T:1844 NOTICE: Using Release Kodi x32 build
19:11:48 T:1844 NOTICE: Kodi compiled Mar 11 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
19:11:48 T:1844 NOTICE: Running on LENOVO 10AY003WUK with Windows 8.1, kernel: Windows NT x86 64-bit version 6.3
19:11:48 T:1844 NOTICE: Host CPU: Intel(R) Core(TM) i3-4150T CPU @ 3.00GHz, 4 cores available
19:11:48 T:1844 NOTICE: Desktop Resolution: 1280x1024 32Bit at 32Hz
19:11:48 T:1844 NOTICE: Running with restricted rights
19:11:48 T:1844 NOTICE: Aero is enabled
19:11:48 T:1844 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
19:11:48 T:1844 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
19:11:48 T:1844 NOTICE: special://masterprofile/ is mapped to: C:\Users\Media\AppData\Roaming\Kodi\userdata
19:11:48 T:1844 NOTICE: special://home/ is mapped to: C:\Users\Media\AppData\Roaming\Kodi\
19:11:48 T:1844 NOTICE: special://temp/ is mapped to: C:\Users\Media\AppData\Roaming\Kodi\cache
19:11:48 T:1844 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
19:11:48 T:1844 NOTICE: Local hostname: XBMC
19:11:48 T:1844 NOTICE: Log File is located: C:\Users\Media\AppData\Roaming\Kodi\kodi.log
19:11:48 T:1844 NOTICE: load settings...
19:11:48 T:1844 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
19:11:48 T:1844 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
19:11:48 T:1844 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:11:48 T:1844 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:11:48 T:1844 NOTICE: Default DVD Player: dvdplayer
19:11:48 T:1844 NOTICE: Default Video Player: dvdplayer
19:11:48 T:1844 NOTICE: Default Audio Player: paplayer
19:11:48 T:1844 NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:11:48 T:1844 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
19:11:48 T:1844 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
19:11:48 T:1844 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:11:48 T:1844 NOTICE: Loaded playercorefactory configuration
19:11:48 T:1844 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:11:48 T:1844 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:11:48 T:8272 NOTICE: Thread ActiveAE start, auto delete: false
19:11:48 T:16928 NOTICE: Thread AESink start, auto delete: false
19:11:48 T:8272 NOTICE: Found 2 Lists of Devices
19:11:48 T:8272 NOTICE: Enumerated DIRECTSOUND devices:
19:11:48 T:8272 NOTICE: Device 1
19:11:48 T:8272 NOTICE: m_deviceName : {6C26BA7D-F0B2-4225-B422-8168C5261E45}
19:11:48 T:8272 NOTICE: m_displayName : Network Device - Remote Audio
19:11:48 T:8272 NOTICE: m_displayNameExtra: DIRECTSOUND: Remote Audio
19:11:48 T:8272 NOTICE: m_deviceType : AE_DEVTYPE_PCM
19:11:48 T:8272 NOTICE: m_channels : FL,FR
19:11:48 T:8272 NOTICE: m_sampleRates : 44100
19:11:48 T:8272 NOTICE: m_dataFormats : AE_FMT_FLOAT
19:11:48 T:8272 NOTICE: Device 2
19:11:48 T:8272 NOTICE: m_deviceName : default
19:11:48 T:8272 NOTICE: m_displayName : default
19:11:48 T:8272 NOTICE: Enumerated WASAPI devices:
19:11:48 T:8272 NOTICE: m_displayNameExtra: WASAPI: Remote Audio
19:11:48 T:1844 NOTICE: Running database version Addons16
19:11:48 T:1844 NOTICE: ADDONS: Using repository repository.addonscriptorde-beta
19:11:48 T:1844 NOTICE: ADDONS: Using repository repository.xbmc.org
19:11:48 T:19404 NOTICE: Thread RemoteControl start, auto delete: false
19:11:48 T:12800 NOTICE: Thread PeripBusCEC start, auto delete: false
19:11:48 T:256 NOTICE: Thread PeripBusUSB start, auto delete: false
19:11:48 T:1844 NOTICE: Found screen: Dummy Monitor on RDPUDD Chained DD, adapter 0.
19:11:48 T:18780 NOTICE: Thread JobWorker start, auto delete: true
19:11:48 T:1844 NOTICE: Primary mode: [email protected] 32.00 - Full Screen
19:11:48 T:1844 NOTICE: Additional mode: [email protected] 32.00 - Full Screen
19:11:48 T:1844 NOTICE: Checking resolution 16
19:11:48 T:1844 NOTICE: Running database version ViewModes6
19:11:48 T:1844 NOTICE: Running database version Textures13
19:11:48 T:1844 NOTICE: Running database version MyMusic48
19:11:48 T:1844 NOTICE: Running database version MyVideos90
19:11:48 T:1844 NOTICE: Running database version TV26
19:11:48 T:1844 NOTICE: Running database version Epg8
19:11:48 T:1844 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
19:11:48 T:1844 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
19:11:48 T:1844 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
19:11:49 T:1844 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
19:11:49 T:14828 NOTICE: Thread LanguageInvoker start, auto delete: false
19:11:49 T:1844 NOTICE: Previous line repeats 9 times.
19:11:49 T:1844 NOTICE: initialize done
19:11:49 T:16132 NOTICE: Thread LanguageInvoker start, auto delete: false
19:11:49 T:1844 NOTICE: Running the application...
19:11:49 T:1844 NOTICE: starting zeroconf publishing
19:11:49 T:17900 NOTICE: Thread LanguageInvoker start, auto delete: false
19:11:49 T:1844 NOTICE: Webserver: Starting...
19:11:49 T:19464 NOTICE: Thread JobWorker start, auto delete: true
19:11:49 T:1844 NOTICE: WebServer: Started the webserver
19:11:49 T:1844 NOTICE: starting upnp controller
19:11:49 T:12804 NOTICE: Thread JobWorker start, auto delete: true
19:11:49 T:1844 NOTICE: starting upnp server
19:11:49 T:1844 NOTICE: starting upnp renderer
19:11:49 T:1844 NOTICE: ES: Starting event server
19:11:49 T:17744 NOTICE: Thread EventServer start, auto delete: false
19:11:49 T:11996 NOTICE: Thread TCPServer start, auto delete: false
19:11:49 T:17744 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
19:11:49 T:17744 NOTICE: UDP: Listening on port 9777
19:11:49 T:9212 NOTICE: Thread RSSReader start, auto delete: false
19:11:49 T:19464 ERROR: CDVDDemuxFFmpeg::Open - Error, could not open file F:\TV\The Returned (US)\The Returned (US) - 1x03 - Julie.mkv
19:11:49 T:8968 NOTICE: -->Python Interpreter Initialized<--
19:11:50 T:15224 NOTICE: Thread LanguageInvoker start, auto delete: false
19:11:51 T:4680 NOTICE: -->Python Interpreter Initialized<--
19:11:51 T:11224 NOTICE: Previous line repeats 10 times.
19:11:51 T:11224 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.13)
19:11:51 T:14828 NOTICE: service.libraryautoupdate-0.9.4 : Update Library Service starting...
19:11:52 T:14828 NOTICE: service.libraryautoupdate-0.9.4 : update timers
19:11:52 T:14828 NOTICE: service.libraryautoupdate-0.9.4 : Creating timer for Video Library
19:11:52 T:15224 NOTICE: -->Python Interpreter Initialized<--
19:11:52 T:13896 NOTICE: StorageServer Module loaded RUN
19:11:52 T:13896 NOTICE: StorageClient-2.5.4 Starting server
19:11:52 T:7616 NOTICE: 1Channel: Service: Installed Version: 2.5.55
19:11:53 T:7616 NOTICE: 1Channel: Loading sqlite3 as DB engine
19:11:53 T:7616 NOTICE: 1Channel: Service: Resetting...
19:11:53 T:7616 NOTICE: 1Channel: Service: starting...
19:11:54 T:15224 NOTICE: weather.metoffice: Fetching Hourly Observation for 'Heathrow (3772)' from the Met Office...
19:11:54 T:15224 SEVERE: weather.metoffice: Traceback (most recent call last):
File "C:\Users\Media\AppData\Roaming\Kodi\addons\weather.metoffice\src\metoffice\utilities.py", line 22, in wrapper
return f(*args, **kwds)
File "C:\Users\Media\AppData\Roaming\Kodi\addons\weather.metoffice\src\metoffice\default.py", line 37, in main
properties.observation()
File "C:\Users\Media\AppData\Roaming\Kodi\addons\weather.metoffice\src\metoffice\utilities.py", line 52, in wrapper
return f(*args, **kwargs)
File "C:\Users\Media\AppData\Roaming\Kodi\addons\weather.metoffice\src\metoffice\properties.py", line 23, in observation
data=json.load(open(filename))
File "C:\Users\Media\AppData\Roaming\Kodi\addons\weather.metoffice\src\metoffice\urlcache.py", line 37, in __exit__
self.flush()
File "C:\Users\Media\AppData\Roaming\Kodi\addons\weather.metoffice\src\metoffice\urlcache.py", line 51, in flush
if not os.path.isfile(entry['resource']) or utilities.strptime(entry['expiry'], self.TIME_FORMAT) < datetime.utcnow():
File "C:\Users\Media\AppData\Roaming\Kodi\addons\weather.metoffice\src\metoffice\utilities.py", line 16, in strptime
return datetime.fromtimestamp(time.mktime(time.strptime(dt, fmt)))
ImportError: Failed to import _strptime because the import lockis held by another thread.
19:11:54 T:16132 NOTICE: $$$ [xbmc.callbacks2] - Starting xbmc.callbacks2 version 0.0.6
19:11:55 T:10648 NOTICE: Thread VideoInfoScanner start, auto delete: false
19:11:55 T:10648 NOTICE: CVideoDatabase::CleanDatabase: Starting videodatabase cleanup ..
19:11:55 T:10648 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.iplayer/?pid=b0441m7x
19:11:55 T:10648 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.iplayer/?pid=bbc_news24&feed_channel=bbc_news24
19:11:55 T:10648 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.iplayer/?pid=bbc_one&feed_channel=bbc_one
19:11:56 T:10648 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.youtube/?action=play_video&videoid=2TQ-pOvI6Xo
19:11:56 T:10648 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.youtube/?action=play_video&videoid=9u4FHmId-Y0
19:11:56 T:10648 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.youtube/?action=play_video&videoid=WT_xpFZe20A
19:11:56 T:10648 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.youtube/?action=play_video&videoid=ayTnvVpj9t4
19:11:56 T:10648 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.youtube/?action=play_video&videoid=gLvmVnKT4cc
19:11:56 T:10648 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.youtube/?action=play_video&videoid=tSVeDx9fk60
19:11:56 T:10648 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.youtube/?action=play_video&videoid=whgBnumr3QQ
19:11:56 T:10648 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.youtube/?action=play_video&videoid=xT5qhPoRS9g
19:11:56 T:10648 NOTICE: CVideoDatabase::CleanDatabase: Cleaning videodatabase done. Operation took 00:00
19:11:57 T:15100 NOTICE: Thread MusicInfoScanner start, auto delete: false
19:11:57 T:15100 NOTICE: CMusicDatabase::Cleanup: Starting musicdatabase cleanup ..
19:11:57 T:15100 NOTICE: CMusicDatabase::Cleanup: Cleaning musicdatabase done. Operation took 00:00
19:11:58 T:12824 NOTICE: Thread BackgroundLoader start, auto delete: false
19:12:01 T:3064 NOTICE: Previous line repeats 1 times.
19:12:01 T:3064 NOTICE: Thread VideoInfoScanner start, auto delete: false
19:12:01 T:3064 NOTICE: VideoInfoScanner: Starting scan ..
19:12:02 T:3064 WARNING: No information found for item 'F:\TV\Agents of Shield\', it won't be added to the library.
19:12:02 T:3064 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
19:12:03 T:14828 NOTICE: service.libraryautoupdate-0.9.4 : update timers
19:12:03 T:14828 NOTICE: service.libraryautoupdate-0.9.4 : Creating timer for Video Library
19:12:04 T:11120 NOTICE: Thread BackgroundLoader start, auto delete: false
19:12:18 T:16132 NOTICE: $$$ [xbmc.callbacks2] - Stopped xbmc.callbacks2
19:12:18 T:19524 NOTICE: Thread BackgroundLoader start, auto delete: false
19:12:20 T:2892 NOTICE: Thread LanguageInvoker start, auto delete: false
19:12:20 T:2892 NOTICE: -->Python Interpreter Initialized<--
19:12:21 T:18780 ERROR: CDVDDemuxFFmpeg::Open - Error, could not open file F:\TV\The Returned (US)\The Returned (US) - 1x03 - Julie.mkv
19:12:23 T:12668 NOTICE: Thread BackgroundLoader start, auto delete: false
19:12:36 T:18840 NOTICE: Thread LanguageInvoker start, auto delete: false
19:12:36 T:19580 NOTICE: Thread BackgroundLoader start, auto delete: false
19:12:36 T:18840 NOTICE: -->Python Interpreter Initialized<--
19:12:36 T:18840 NOTICE: $$$ [xbmc.callbacks2] - Starting xbmc.callbacks2 version 0.0.6
19:12:37 T:14528 NOTICE: Thread BackgroundLoader start, auto delete: false
19:12:47 T:9424 NOTICE: Previous line repeats 1 times.
19:12:47 T:9424 NOTICE: Thread LanguageInvoker start, auto delete: false
19:12:47 T:9424 NOTICE: -->Python Interpreter Initialized<--
19:12:47 T:9424 WARNING: CPythonInvoker(15): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
19:12:47 T:9424 NOTICE: $$$ xbmc.callbacks2 - Starting tester.py from cwd: C:\Users\Media\AppData\Roaming\Kodi\addons\service.xbmc.callbacks2-master
19:12:48 T:9424 NOTICE: $$$ [xbmc.callbacks2] - Executing command: [C:\Users\Media\Desktop\Cinemapy.py] for event: onPlaybackStarted
19:12:48 T:9424 NOTICE: $$$ [xbmc.callbacks2] - Command for onPlaybackStarted executed successfully
19:12:48 T:18724 NOTICE: Thread LanguageInvoker start, auto delete: false
19:12:48 T:18724 NOTICE: -->Python Interpreter Initialized<--
19:12:48 T:18724 WARNING: CPythonInvoker(16): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
19:12:48 T:18724 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.WindowsError'>
Error Contents: [Error 2] The system cannot find the file specified
File "C:\Users\Media\Desktop\Cinemapy.py", line 2, in <module>
p = Popen("Cinema.bat", cwd=r"c:\users\media\desktop")
File "C:\Program Files (x86)\Kodi\system\python\Lib\subprocess.py", line 710, in __init__
errread, errwrite)
File "C:\Program Files (x86)\Kodi\system\python\Lib\subprocess.py", line 958, in _execute_child
startupinfo)
WindowsError: [Error 2] The system cannot find the file specified
19:13:11 T:10932 NOTICE: Thread LanguageInvoker start, auto delete: false
19:13:11 T:10932 NOTICE: -->Python Interpreter Initialized<--
19:13:11 T:10932 WARNING: CPythonInvoker(17): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
19:13:11 T:10932 NOTICE: $$$ xbmc.callbacks2 - Starting tester.py from cwd: C:\Users\Media\AppData\Roaming\Kodi\addons\service.xbmc.callbacks2-master
19:13:12 T:10932 NOTICE: $$$ [xbmc.callbacks2] - Executing command: [[u'C:\\Users\\Media\\Desktop\\Cinemapy.py']] for event: onPlaybackStarted
19:13:12 T:10932 NOTICE: $$$ [xbmc.callbacks2] - Command for onPlaybackStarted resulted in ERROR: <attribute 'message' of 'exceptions.BaseException' objects>
File "C:\Users\Media\AppData\Roaming\Kodi\addons\service.xbmc.callbacks2-master\default.py", line 480, in run
result = subprocess.check_output(margs, shell=self.needs_shell, stderr=subprocess.STDOUT)
File "C:\Program Files (x86)\Kodi\system\python\Lib\subprocess.py", line 566, in check_output
process = Popen(stdout=PIPE, *popenargs, **kwargs)
errread, errwrite)
startupinfo)
WindowsError: [Error 193] %1 is not a valid Win32 application
19:14:27 T:18840 NOTICE: $$$ [xbmc.callbacks2] - Invalid url: www.google.com
19:14:27 T:18840 NOTICE: $$$ [xbmc.callbacks2] - Due to errors, unable to register command: www.google.com
19:14:30 T:5252 NOTICE: Thread LanguageInvoker start, auto delete: false
19:14:30 T:5252 NOTICE: -->Python Interpreter Initialized<--
19:14:30 T:5252 WARNING: CPythonInvoker(18): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
19:14:30 T:5252 NOTICE: $$$ xbmc.callbacks2 - Starting tester.py from cwd: C:\Users\Media\AppData\Roaming\Kodi\addons\service.xbmc.callbacks2-master
19:14:30 T:5252 NOTICE: $$$ [xbmc.callbacks2] - Invalid url: www.google.com
19:14:30 T:5252 NOTICE: $$$ [xbmc.callbacks2] - Due to errors, unable to register command: www.google.com
19:17:04 T:4916 NOTICE: Thread JobWorker start, auto delete: true
19:17:19 T:13988 NOTICE: Thread LanguageInvoker start, auto delete: false
19:17:19 T:13988 NOTICE: -->Python Interpreter Initialized<--
19:17:19 T:13988 WARNING: CPythonInvoker(19): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
19:17:19 T:13988 NOTICE: $$$ xbmc.callbacks2 - Starting tester.py from cwd: C:\Users\Media\AppData\Roaming\Kodi\addons\service.xbmc.callbacks2-master
19:17:20 T:13988 NOTICE: $$$ [xbmc.callbacks2] - Executing command: [[u'C:\\Users\\Media\\Desktop\\Cinema.exe']] for event: onPlaybackStarted
19:17:20 T:13988 NOTICE: $$$ [xbmc.callbacks2] - Command for onPlaybackStarted resulted in ERROR: 'lwrf' is not recognized as an internal or external command,
operable program or batch file.
19:17:57 T:20076 NOTICE: Thread LanguageInvoker start, auto delete: false
19:17:57 T:20076 NOTICE: -->Python Interpreter Initialized<--
19:17:57 T:20076 WARNING: CPythonInvoker(20): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
19:17:57 T:20076 NOTICE: $$$ xbmc.callbacks2 - Starting tester.py from cwd: C:\Users\Media\AppData\Roaming\Kodi\addons\service.xbmc.callbacks2-master
19:17:57 T:20076 NOTICE: $$$ [xbmc.callbacks2] - Executing command: [[u'C:\\Users\\Media\\Desktop\\Cinema.exe']] for event: onPlaybackStarted
19:17:58 T:20076 NOTICE: $$$ [xbmc.callbacks2] - Command for onPlaybackStarted resulted in ERROR: 'lwrf' is not recognized as an internal or external command,
19:22:22 T:12668 NOTICE: Thread JobWorker start, auto delete: true
19:24:12 T:12700 NOTICE: Thread LanguageInvoker start, auto delete: false
19:24:12 T:12700 NOTICE: -->Python Interpreter Initialized<--
19:24:13 T:1844 NOTICE: Storing total System Uptime
19:24:13 T:1844 NOTICE: Saving settings
19:24:13 T:1844 NOTICE: stop all
19:24:13 T:1844 NOTICE: stop player
19:24:13 T:1844 NOTICE: ES: Stopping event server
19:24:13 T:1844 NOTICE: stopping upnp
19:24:13 T:17744 NOTICE: ES: UDP Event server stopped
19:24:13 T:1844 NOTICE: stopping zeroconf publishing
19:24:13 T:1844 NOTICE: Webserver: Stopping...
19:24:13 T:1844 NOTICE: WebServer: Stopped the webserver
19:24:13 T:1844 NOTICE: Webserver: Stopped...
19:24:13 T:1844 NOTICE: stop sap announcement listener
19:24:13 T:1844 NOTICE: clean cached files!
19:24:13 T:1844 NOTICE: unload skin
19:24:14 T:7616 NOTICE: 1Channel: Service: shutting down...
19:24:15 T:13716 WARNING: CPythonInvoker(2, C:\Users\Media\AppData\Roaming\Kodi\addons\service.skin.widgets\default.py): the python script "C:\Users\Media\AppData\Roaming\Kodi\addons\service.skin.widgets\default.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui::Window,class PythonBindings::XBMCAddon_xbmc_Player_Director,class PythonBindings::XBMCAddon_xbmc_Monitor_Director
19:24:15 T:13896 NOTICE: StorageServer-2.5.4 Closed down
19:24:16 T:7368 WARNING: CPythonInvoker(5, C:\Users\Media\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py): the python script "C:\Users\Media\AppData\Roaming\Kodi\addons\service.library.data.provider\service.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui::Window,class PythonBindings::XBMCAddon_xbmc_Monitor_Director,class PythonBindings::XBMCAddon_xbmc_Player_Director
19:24:17 T:11224 NOTICE: script.tv.show.next.aired: ### abort requested -- stopping background processing
19:24:17 T:18840 NOTICE: $$$ [xbmc.callbacks2] - Stopped xbmc.callbacks2
19:24:17 T:1844 NOTICE: stopped
19:24:17 T:1844 NOTICE: destroy
19:24:17 T:1844 NOTICE: closing down remote control service
19:24:17 T:1844 NOTICE: unload sections
19:24:17 T:1844 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:24:17 T:1844 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
19:24:17 T:1844 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
19:24:17 T:1844 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
19:24:17 T:1844 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
19:24:17 T:1844 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
19:24:17 T:1844 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
19:24:17 T:1844 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
19:24:17 T:1844 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
19:24:17 T:1844 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
19:24:17 T:1844 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
19:24:17 T:1844 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
19:24:17 T:1844 NOTICE: application stopped...
19:24:17 T:1844 ERROR: dllFreeLibrary - Invalid hModule specified
Any help is really appreciated as I'd love to get this working , and I feel like its quite obvious
Keir
I'll try to look further into this on Thursday or so. I'm travelling. Please post logs to pastebin in the future and put a link here instead of a full log.
At first glance you don't have the path/file correct for the first call and I'll look into the ill call but looks improperly formatted.
Hi Ken
I've tried directing XBMC to run CMD from system 32 and using the batch command as the arguments but to no avail , what am I doing wrong ? Im a little confused.
Hi All,
I don't use this addon myself, but I currently have an addon:
VideoScreensaver
This (as the name suggests) plays a video for the screenaver. Due to the way it has the do things, it might cause users of your addon to not get the messages they expected when the screensaver starts/stops.
This was highlighted to me in the following posts:
1984517 (post)
1986618 (post)
There is not much I can do about the notification messages being generated, but I have added some flags so other addon developers can detect what VideoScreensaver is doing:
http://kodi.wiki/view/Add-on:VideoScreen...Is_Running
I hope this helps anyone else seeing this problem.
Rob
I'm trying to do the simplest thing possible with this addon; but can't get it to work... execute a Windows executable on Player start. And, execute a Windows executable on Player stop. I'm not a python/Linux expert. I'm using Windows 8.1
I tried the most obvious approach below (just point directly to the Windows EXE)... which didn't do anything.
EDIT: It looks like the problem is that I'm using Helix. I upgraded to the below addon; which worked immediately.
https://github.com/KenV99/service.xbmc.callbacks2
Is there a way to have a script that only runs when I'm playing (streaming) from a particular add-on? If I'm playing a file out of my library then I don't need my script to run but if I'm streaming then I want to run a script that pauses other internet activity. I'm guessing there isn't a native way to do this but maybe there's a work around where the script runs every time something plays and then the script checks to see what is playing and only executes the meat of the script based on what is playing. Is there a way for a python sc
Hi Ken,
how could I execute a script at Kodi shutdown?
I would need it to shutdown an amplifyer.
I can start it through a startup script outside kodi but the turn off-feature is still missing
Regards
I agree with tomrey. SHutdown script is needed. I want to use the shutdown script so a user can select a different remote.
Is there some way to detect if kodi is in Kiosk mode? Like to disable automatic shutdown when chrome launcher is started.
(2015-05-09, 12:11)tomrey Wrote: [ -> ]Hi Ken,
Regards
(2015-05-10, 17:44)tekno Wrote: [ -> ]I agree with tomrey. SHutdown script is needed. I want to use the shutdown script so a user can select a different remote.
These might be possible if whatever code you are running is not going to be python running on the Kodi python interpreter.
Kodi terminates all scripts if they don't shutdown in 5 seconds, so unless you are launching an independent process, whatever you are doing has to complete fast.
And no, there is no way to change that or abort the shutdown. So waiting for a user prompt to select something would have to programmed with it's own independent GUI.
Of note, Kodi does NOT play nice with the multiprocessing module, so don't go down that path.
