(2015-09-13, 14:23)jknight2014 Wrote: [ -> ]Code:
08:15:31 T:139753114765056 WARNING: CPythonInvoker(191): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
08:15:31 T:139753114765056 NOTICE: $$$ xbmc.callbacks2 - Starting tester.py from cwd: /home/kodi/.kodi/addons/service.xbmc.callbacks2-master
08:15:31 T:139753114765056 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named pydevd
File "/home/kodi/.kodi/addons/service.xbmc.callbacks2-master/tester.py", line 52, in <module>
from default import Dispatcher, read_settings, __options__
File "/home/kodi/.kodi/addons/service.xbmc.callbacks2-master/default.py", line 34, in <module>
import pydevd
ImportError: No module named pydevd
This hapend when I tried to test. I set it to 3 minuets and waited 10 and nothing hapend. No new lines in the log. The Screen Saver came on so it is idle.
Make sure you changed 'idledebug' and not 'debug' because that error indicates that you changed 'debug' because it is trying to invoke the pydevd debugger which I doubt you have installed.
(2015-09-13, 14:10)trogggy Wrote: [ -> ]Quick question Ken - sorry if I've missed something, but should this be working on Helix?
I'm using openelec 5.08 (kodi14.2) and I've set up to return to the home page (built-in - XBMC.ActivateWindow(Home)) on screensaver, sleep (poweroff) and resume. It works great on the screensaver but not the other 2.
Have I missed something obvious, or should I post some logs?
TIA.
Sleep is not one of the triggers so I am at a loss there.
If you try to use the 'on Shutdown' trigger, you may miss the change in screens because Kodi shuts down immediately after that event fires.
Resume is only resume from playback being paused. I would doubt that you really want to show the home screen every time you resume playback after pausing.
(2015-09-13, 15:11)KenV99 Wrote: [ -> ]Sleep is not one of the triggers so I am at a loss there.
Resume - sorry meant startup - I can see that's a red herring anyway, as it isn't starting up - it's waking up - and if starts from cold it's on the Home screen anyway. Sorry for the confusion there, my fault.
I have the shutdown function configured to sleep rather than poweroff IYSWIM. So I'm sending a shutdown command in kodi, I'd have expected it to be on the home screen when it wakes. No?
Edit:
Just checked the log and (unsurprisingly) there's no mention of anything happening...
Would it be possible to add sleep as a trigger to perform an action?
(2015-09-13, 15:34)trogggy Wrote: [ -> ]Resume - sorry meant startup - I can see that's a red herring anyway, as it isn't starting up - it's waking up - and if starts from cold it's on the Home screen anyway. Sorry for the confusion there, my fault.
Edit:
Ok. The 'on Shutdown' event only fires when Kodi is actually shutting down (i.e. a Kodi abort has been requested). As far as how your system is 'sleeping' - do you mean in Settings -> System -> Power saving that you have set 'Put display to sleep on idle'? If so, you can try using the 'on Idle' trigger. That is the only 'sleep' setting that I am aware of in the standard build. There could be something specific to OpenELEC. If there is, then, no the only events that can be easily coded are those built into the Python api: see
http://mirrors.kodi.tv/docs/python-docs/...ml#Monitor
No. What I've done is to map the shutdown function to 'suspend' in system > settings > power saving. That's a kodi core feature, not specific to openelec.
My first attempt at this was to use 'on idle' and it triggered at strange times (eg mid-music). Not to worry - I've put together a shutdown (sleep) script and mapped it to a button, which does the same job.
Edit: log snippet of what happens when I press 'clear' on the remote (read as delete, mapped to shutdown, which triggers suspend - bit convoluted, eh?)
15:42:49 T:140711430465408 DEBUG: LIRC: Update - NEW at 89803:6f 0 KEY_DELETE devinput (KEY_DELETE)
15:42:49 T:140711430465408 DEBUG: OnKey: 249 (0xf9) pressed, action is ShutDown()
15:42:49 T:140711430465408 DEBUG: ------ Window Init (DialogBusy.xml) ------
15:42:49 T:140711430465408 DEBUG: LogindUPowerSyscall: Received PrepareForSleep with arg 1
15:42:49 T:140711430465408 DEBUG: CAnnouncementManager - Announcement: OnSleep from xbmc
15:42:49 T:140711430465408 DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnSleep
15:42:49 T:140711430465408 NOTICE: OnSleep: Running sleep jobs
15:42:49 T:140711430465408 NOTICE: OnSleep: Stopping lirc
15:42:49 T:140711430465408 INFO: LIRC setUsed: disabled
15:42:49 T:140711430465408 DEBUG: CApplication::CloseNetworkShares: Closing all network shares
15:42:49 T:140711430465408 NOTICE: OnSleep: Going to sleep up
15:42:49 T:140711430465408 DEBUG: LogindUPowerSyscall - delay lock released
I got it working. A restart was required after changing the setting. However kodi is idle while playing a video. So it shuts the tv off during a show. Is that normal?
(2015-09-14, 03:18)jknight2014 Wrote: [ -> ]I got it working. A restart was required after changing the setting. However kodi is idle while playing a video. So it shuts the tv off during a show. Is that normal?
That, indeed, is the default behavior of Kodi's xbmc.GetGlobalIdleTime function - it does not reset itself while playing a video or music.
However, I think that it would be more useful to most if Kodi was not considered idle while playing as in your case and troggy's.
So I made a few changes so that the idle timer does not start counting unless the player is not playing and pushed it to git hub.
Let me know if it works for you.
(2015-09-14, 12:50)KenV99 Wrote: [ -> ]That, indeed, is the default behavior of Kodi's xbmc.GetGlobalIdleTime function - it does not reset itself while playing a video or music.
It seems to be working great. Thanks! I agree playing video should not be idle.
I try to use it in RPi OSMC version.
it does not work. I ssume it did not intialized propertly at all.
have any idea how to fix?
here is the log:
13:51:29 32.128613 T:1759802400 NOTICE: -->Python Interpreter Initialized<--
13:51:31 33.935440 T:1503654944 NOTICE: Thread BackgroundLoader start, auto delete: false
13:51:31 34.173580 T:1503654944 NOTICE: Previous line repeats 1 times.
13:51:31 34.173836 T:1503654944 NOTICE: Thread JobWorker start, auto delete: true
13:53:06 128.746902 T:1470100512 NOTICE: Thread LanguageInvoker start, auto delete: false
13:53:06 128.748657 T:1717335072 NOTICE: Thread JobWorker start, auto delete: true
13:53:07 129.354507 T:1470100512 NOTICE: -->Python Interpreter Initialized<--
13:53:14 136.895264 T:1470100512 NOTICE: Thread BackgroundLoader start, auto delete: false
13:53:25 147.743332 T:1528820768 NOTICE: Previous line repeats 2 times.
13:53:25 147.743652 T:1528820768 NOTICE: Thread JobWorker start, auto delete: true
13:58:04 426.967926 T:1958097456 NOTICE: Previous line repeats 3 times.
13:58:04 426.968201 T:1958097456 ERROR: CPythonInvoker(9, /home/osmc/.kodi/addons/service.xbmc.callbacks-0.5/default.py): script didn't stop in 5 seconds - let's kill it
13:58:04 427.007233 T:1503654944 NOTICE: Thread JobWorker start, auto delete: true
13:58:04 427.144135 T:1545597984 NOTICE: Thread BackgroundLoader start, auto delete: false
13:58:07 429.420166 T:1545597984 NOTICE: Thread LanguageInvoker start, auto delete: false
13:58:07 429.609436 T:1528820768 NOTICE: Thread BackgroundLoader start, auto delete: false
13:58:07 429.690613 T:1681847328 WARNING: CPythonInvoker(9, /home/osmc/.kodi/addons/service.xbmc.callbacks-0.5/default.py): the python script "/home/osmc/.kodi/addons/service.xbmc.callbacks-0.5/default.py" has left several classes in memory that we couldn't clean up. The classes include: N14PythonBindings31XBMCAddon_xbmc_Monitor_DirectorE,N14PythonBindings30XBMCAddon_xbmc_Player_DirectorE
13:58:07 429.981659 T:1545597984 NOTICE: -->Python Interpreter Initialized<--
13:58:10 432.544098 T:1681847328 NOTICE: Thread JobWorker start, auto delete: true
13:58:12 435.256744 T:1717335072 NOTICE: Previous line repeats 2 times.
13:58:12 435.257050 T:1717335072 NOTICE: Thread BackgroundLoader start, auto delete: false
13:58:15 437.688690 T:1717335072 NOTICE: Previous line repeats 1 times.
(2015-10-04, 14:06)JANGER Wrote: [ -> ]I try to use it in RPi OSMC version.
here is the log:
Please post a full log to pastebin.com or xbmclogs.com and post the link here.
Moderators frown upon posting whole logs in the forum and I cannot tell anything looking at this fragment.
Also, it looks like you are using the original script. I can provide more help and there is more debugging information if you install my fork:
https://github.com/KenV99/service.xbmc.callbacks2
Never mind. I fixed!
Thanks KenV99. I've written this message before server displayed your answer above.
I found:
(2015-06-22, 23:49)KenV99 Wrote: [ -> ]If you installed my version from GitHub there aren't any dependencies.
This is displayed as version 2.
And it works fantastic in RPi OSMC !
That's what I need! Dimming lights im my cinema automatically!
I send ordinary TCP/IP GET parameters to wifi-enabled dimmer.
Next step: can I use this add-on to play some video file before the movie start playing?
I know there is Cinema Experience add-on. But I do'n want such many features. And it also has problems in RPi.
So... sould I write some python script? and use it oposite to the above ordinary GET messsage.
Inside such script: execute the selected video file, wait the end, send tcpip message, start playing the main movie.
Is it possible?
here is the log:
(2015-10-04, 14:49)JANGER Wrote: [ -> ]This is displayed as version 2.
Is it possible?
You'll need to write a python script which subclasses xbmc.Player():
http://mirrors.kodi.tv/docs/python-docs/...tml#Player
Specifically you'll need to:
1) save the current playing file using Player.getPlayingFile()
2) call Player.stop()
3) call Player.start() using the url or whatever it is you want to play. Set a flag so that .onPlayBackStopped() knows to run when this finishes and not when you called stop in step 2.
4) write a routine for Player.onPlayBackStopped() to run the original file that you saved in step 1 only when the flag from step 3 is true
If you really want user interaction to select a file to play before the main video file, then you'll need to write the UI code to display the menu as well.
Although I've outlined the elemental steps you need above, I do not have the time to code this myself. Good luck!
EDIT:
You'll also need to write a main loop that doesn't exit until the onPlayBackStopped() code that restarts the original video file has executed.
I have been using this on linux, and just tried it with a cleanup script on ATV2 as posted below however addon says "Command Not Valid"
I can run the script from the command line. Unfortunately this is very needed on ATV2 due to its lack of ability to automate in other ways
#!/bin/sh
rm -f /home/kodi/kodi_crash*.log
rm -f /home/kodi/.kodi/addons/packages/*.zip
rm -f /home/kodi/.kodi/temp/*.idx
rm -f /home/kodi/.kodi/temp/*.smi
rm -f /home/kodi/.kodi/temp/*.ssa
rm -f /home/kodi/.kodi/temp/*.ass
rm -f /home/kodi/.kodi/temp/*.srt
rm -f /home/kodi/.kodi/temp/*.sub
rm -f /home/kodi/.kodi/temp/*.fi
rm -f /home/kodi/.kodi/temp/*.mpl
rm -f /home/kodi/.kodi/temp/*.cache
rm -f /home/kodi/.kodi/temp/*.dat
rm -f /home/kodi/.kodi/temp/*.zip
rm -f /home/kodi/.kodi/temp/*.rar
rm -f /home/kodi/.kodi/temp/*.mpg
rm -f /home/kodi/.kodi/temp/*.avi
rm -f /home/kodi/.kodi/temp/*.mp4
rm -f /home/kodi/.kodi/temp/*.mkv
rm -f /home/kodi/.kodi/temp/*.3gp
rm -f /home/kodi/.kodi/temp/*.ts
rm -f /private/var/mobile/Library/Preferences/Kodi/addons/packages/*.zip
rm -f /private/var/mobile/Library/Caches/AppleTV/Video/LocalAndRental/*
rm -f /private/var/mobile/Library/Caches/AppleTV/Video/Other/*
rm -f /private/var/cache/apt/archives/*.deb
rm -f /private/var/cache/apt/archives/partial/*
exit 0
also tried with #!bin/bash as first line and either runs when I ssh to atv2 and manually run the script.
Since you didn't link to a log my assumption is that it is the log that says 'Command Not Valid' as opposed to there being an exception/error?
I also assume that you have the above script in a file called script.sh or similar and the permissions/execute bit is properly set (i.e. you aren't root or su when you test it)?
I also assume that you have checked off to run it as a shell command (requires shell)?
I don't have any experience with ATV2 so beyond the above, I don't have any ideas.
Would it be possible to have this script to react on certain addon actions only?
For example only kick in when Retrospect stream stops playing instead of all (local and remote) media?
Or on http or rtmp streams only?
