Full Version: [RELEASE] Execute user scripts on specific XBMC actions (play starts/stops...)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
Thanks. This is cool. I am using it on OS X. Wondering if anyone has been able to run an applescript. I can trigger an app but not a script file.
Edit: Thanks for the info, used bash script.
(2014-01-31, 09:14)activate Wrote: [ -> ]Thanks. This is cool. I am using it on OS X. Wondering if anyone has been able to run an applescript. I can trigger an app but not a script file.
Something like /usr/bin/osascript <scriptname> should work
Is it possible for this add-on to detect which video add-on is being launched then perform an action? Specifically, when I have a certain video streaming add-on start, I'd like to call a script that activates a VPN. Then, when the video streaming add-on is stopped, I'd like to call a script to deactivate the VPN. And then if there's a different video streaming add-on started, it would call a different VPN script? Thanks!
hello,
verry nice script , but how to configure it? perhaps you could help me with a example, like execute /home/xbian/lightsoff.sh when a movie of tv show starts
ps Im just beginning with python so excuse me for my ignorance in the language
Luke
sorry, i found out its really a plugin, i tough it was a script.
how to change it so it doesn't see music as a player?
luke
Great add on! It does what I needed just fine. My only nitpick is that the script I put into the xbmc start option gets abandoned after exiting and shows up on the process list as a zombie! Not a big deal, but it would be nice if that didn't happen.
(2014-02-21, 02:02)metheos Wrote: [ -> ]Great add on! It does what I needed just fine. My only nitpick is that the script I put into the xbmc start option gets abandoned after exiting and shows up on the process list as a zombie! Not a big deal, but it would be nice if that didn't happen.
I was able to get this to work by adding a wait to the process and pointing it to a script that forks the actual script.
class Main:
  def __init__(self):
    self._init_vars()
    self._init_property()
    global script_xbmc_starts
    if script_xbmc_starts:
      log('Going to execute script = "' + script_xbmc_starts + '"')
      try:
          process= subprocess.Popen([script_xbmc_starts])
          process.wait()
      except:
          log('Error executing script when xbmc starts')
    self._daemon()
(2014-02-22, 20:19)metheos Wrote: [ -> ]
class Main:
  def __init__(self):
    self._init_vars()
      try:
          process.wait()
      except:
    self._daemon()
Thanks for this, to be honest it does not happen in my setup (raspbmc) but I will investigate further. Regards,
I have created a new version (v0.5) that I think fixes the possible zombie processes. Thanks for reporting this:
https://github.com/pilluli/service.xbmc....e/v0.5.zip
Regards,
How can I run a file with additional attributes, I need to be able to either:
1 - Link to a shortcut
or
2 - Be able to point to a program like this ""C:\Program Files (x86)\HomeSeer HS2\HsScript.exe" MovieStart.vb"
Is that possible somehow, because in the XBMC interface I can't manually type the script location
(2014-03-01, 09:40)jvc1986 Wrote: [ -> ]How can I run a file with additional attributes, I need to be able to either:
or
Yes, go to addon_data > service.xbmc.callbacks > and manually edit the settings.xml
I'm trying to run a script after library update, but I'm getting the following errors:
13:45:42 T:10988   DEBUG: XBMC callbacks: database updated
13:45:42 T:10988   DEBUG: XBMC callbacks: Going to execute script = "C:\Users\me\myscript.py"
13:45:42 T:10988   DEBUG: XBMC callbacks: ERROR executing script when database updates
The script will run if manually executed through XBMC so I know that it works.
Any ideas?
Sorry to bump this. It would be tremendous if I could get this working. The solution I've been looking for for months.
I would be eternally grateful for any advice that could be offered.
Hi all,
I am using this superb addon on windows.
I use it to pilot my philips hue: 20% light when player starts/resumes, and 100% light when player stops/pauses.
To do so, i create .bat file containing the curl command. It works.
However, when invoking the .bat, there is a console window opening briefly.
I would like the invocation to be invisible.
I tried "start /min light.bat", i tried also "wscript light.vbs" (with adequate code that does not show a window).
Both those fail to be started. And i have no error log. I do no why they are not started: maybe due to presence of an argument?
Any idea to mask that console window?
I currently returned back to .bat file, but it is not sexy...
(2014-03-09, 15:43)flarc Wrote: [ -> ]Hi all,
Can you post the code that you used in the .bat file as well as the code in the .vbs file?
Have you tried inserting a bit of code in either of those files to see if they are being executed? Like create a message box? Once done debugging then you would delete that code.
Hello, thanks for your helps.
1) Ok, so currently, my settings.xml is like this:
<setting id="player_pauses" value="C:\sarah\plugins\fred\bin\huelight_high.bat" />
And the "huelight_high.bat" is like that:
@echo off
c:
cd C:\sarah\plugins\fred\bin
curl http://192.168.1.21/api/newdeveloper/lights/1/state -X PUT -d "{\"on\":true, \"bri\":228}" >> NUL
This works, but i see a brief console window appear.
2) I tried also this (xml manually edited because .vbs is not displayed in xbmc add-on configuration screen):
settings.xml:
<setting id="player_pauses" value="C:\sarah\plugins\fred\bin\huelight_high.vbs" />
huelight_high.vbs:
Set WshShell = WScript.CreateObject("WScript.Shell")
cmd = "C:\sarah\plugins\fred\bin\huelight_high.bat"
Return = WshShell.Run(cmd, 0, True)
set WshShell = Nothing
The huelight_high.bat is unchanged.
If i run manually the vbs, it works without console appearing.
But within XBMC, the command is not performed (which i can see only due to no change of light)
Does not work either with:
settings.xml:
<setting id="player_pauses" value="wscript C:\sarah\plugins\fred\bin\huelight_high.vbs" />
3) I also tried compiling the .bat into .exe, and updating accordingly the settings.xml, but does not work either.
<setting id="player_pauses" value="C:\sarah\plugins\fred\bin\huelight_high.exe" />
4) I did not try yet to put directly the long curl command into the settings.xml (i need to see how to manage the quotes within the command).
5) Last thing i would try (but i do not know yet how to do it) is calling directly a python script (that would be interpreted by xbmc's own python lib) to change hue lights.
If you have an idea to make option#1 or #2 work, it would be helpful, because i would prefer those ways of doing it. But if option#5 would work, i will take it.
