Full Version: Shoutcast features
he guys,
i was browsing through the shoutcast playlist searching for a specific channel .. it took my like 5 minutes to get there .. would it be possible:
- for a search to be implented .. or a way to sort them alphabetically .. (the numbers are sorted now and that dont work that well because they change often)..
- to skip all the sub-"playlist" information and auto start playing file1 or first file with free slot (maybe use numeric buttons (0/tm9) to change file) .. this also benefits performance as the shoutcast list doesnt have to be downloaded every time when changing channel.
- to automaticly skip a channel with next/previous button .. then its as easy as skipping through a list of mp3's
- to have a shoutcast station to be played as default when booting into xbmc .. (btw this is possible with the mp3play python script only the shoutcast information doesn't appear)
- to fix the webserver: shoutcastlist isn't showed correctly .. i get a lot of errors ..
sincerely, mnc_ :thumbsup:
