2013-01-07, 14:31
I am using XBMC Frodo RC3 with the Aeon Nox skin.
I'm completely new to XBMC and in blundering my way around the interface over the weekend I found a couple of menus that appear when the mouse is used but I can't find the keyboard shortcut for them.
The first is some kind of quick list that appears when the mouse is hovered at the top of the screen. Judging from the skin's Kiosk Mode options this appears to be called the "Media Menu" and can be disabled. I'm not too worried about this one, but does it have a keyboard shortcut?
The second is more important and one of two versions of it appear depending on if you are playing an audio file or a video file. It too is activated from hovering the mouse at the top of the screen, and it contains transport controls as well as a bunch of audio and video playback settings that I do not seem to be able to access from anywhere else in the menus.
I've got an eHome remote and I'd like to map these menus to some spare buttons but I can't find the corresponding keyboard shortcuts to launch them. Can anyone help?
