2013-01-08, 00:14
Hi
I have just installed XBMC 11.0 (Eden) and TV Catchup 2.0 EPG (2.1.26) to breathe new life into an original spec Mac Mini from 2005 .... it runs Tiger 10.4.11 on PPC.
The moment I click on any channels it says ' working' in the bottom right corner for about 1 second and then crashes.
(I installed the same software, albeit Intel version of XBMC, on a MacBook Pro Intel Core Duo running Snow Leopard 10.6.8 and it works fine.)
Any idea what could be up regarding PPC?
BTW, I posted on the TV Catchup forum with the conclusion that: "It looks like an issue with XBMC itself".
See here, for TV Catchup forum post and more log info.
Many thanks in advance
Chris
PS - There is maybe nothing interesting in the xbmc.log though the last few lines are here:
The first few lines of XBMC.crash.log are here:
Chris
18:13:07 T:2684415368 ERROR: ClearBlock: Trying to clear non existent block /Users/chris/Library/Application Support/XBMC/addons/script.tvcatchup
18:13:07 T:2684415368 NOTICE: Using GL_TEXTURE_RECTANGLE_ARB
18:13:07 T:2684415368 NOTICE: GL: Shaders support not present, falling back to SW mode
18:13:07 T:2684415368 NOTICE: GL: NPOT textures are supported through GL_ARB_texture_rectangle extension
18:13:07 T:2684415368 NOTICE: GL: Using GL_ARB_pixel_buffer_object
18:13:08 T:66014208 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
Host Name: chris-mac-mini
Date/Time: 2013-01-04 18:13:07.952 +0100
OS Version: 10.4.11 (Build 8S165)
Report Version: 4
Command: XBMC
Path: /Applications/XBMC.app/Contents/MacOS/XBMC
Parent: WindowServer [56]
Version: 11.0 (Git-20120321-14feb09)
PID: 216
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_INVALID_ADDRESS (0x0001) at 0x0dbc5000
Thread 0 Crashed:
0 swscale-0-powerpc-osx.so 0x0a9a9398 altivec_yuv2_bgra + 456
1 swscale-0-powerpc-osx.so 0x0a999a44 sws_scale + 1828
2 com.teamxbmc.xbmc 0x000fb110 CLinuxRendererGL::ToRGBFrame(YV12Image*, unsigned, unsigned) + 592
3 com.teamxbmc.xbmc 0x000fb2c4 CLinuxRendererGL::UploadRGBTexture(int) + 196
4 com.teamxbmc.xbmc 0x000fadf8 CLinuxRendererGL::Render(unsigned, int) + 152
5 com.teamxbmc.xbmc 0x000fce40 CLinuxRendererGL::RenderUpdate(bool, unsigned, unsigned) + 976
6 com.teamxbmc.xbmc 0x000fefc8 CXBMCRenderManager::PresentSingle(bool, unsigned, unsigned) + 120
7 com.teamxbmc.xbmc 0x000ff144 CXBMCRenderManager::Render(bool, unsigned, unsigned) + 260
8 com.teamxbmc.xbmc 0x00100368 CXBMCRenderManager::Present() + 600
9 com.teamxbmc.xbmc 0x00023c40 CApplication::RenderNoPresent() + 176
10 com.teamxbmc.xbmc 0x00013c74 CApplication::Render() + 1060
11 com.teamxbmc.xbmc 0x005938a0 CXBApplicationEx::Run() + 320
12 com.teamxbmc.xbmc 0x00593c28 SDL_main + 232
13 com.teamxbmc.xbmc 0x006883d0 main + 1488
14 com.teamxbmc.xbmc 0x0000ed8c _start + 760
15 com.teamxbmc.xbmc 0x0000ea90 start + 48
