A bug under Mac with kxAudio driver (Audigy 2 ZS audio card).
If I select the kxAudio ( kx SB0350 10K2 [c000]) as the audio output device, only the left channel of sound is hearable, the right channel is mute.
I just use the simplest 2.0/2.1 configuration, and tested with a lot of videos.
And other apps under mac can take both channel of SoundBox workable, such as iTunes and Diablo3
My XBMC version is 12.0-RC3
09:34:28 T:140735229206912 NOTICE: -----------------------------------------------------------------------
09:34:28 T:140735229206912 NOTICE: Starting XBMC (12.0-RC3 Git:20130102-7a6cb7f), Platform: Darwin OSX (12.2.1 x86_64, Version 10.8.2 (Build 12C3104)). Built on Jan 3 2013
09:34:28 T:140735229206912 NOTICE: special://xbmc/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
09:34:28 T:140735229206912 NOTICE: special://xbmcbin/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
09:34:28 T:140735229206912 NOTICE: special://masterprofile/ is mapped to: /Users/kirbyzhou/Library/Application Support/XBMC/userdata
09:34:28 T:140735229206912 NOTICE: special://home/ is mapped to: /Users/kirbyzhou/Library/Application Support/XBMC
09:34:28 T:140735229206912 NOTICE: special://temp/ is mapped to: /Users/kirbyzhou/.xbmc/temp
09:34:28 T:140735229206912 NOTICE: special://frameworks/ is mapped to: /Applications/XBMC.app/Contents/Frameworks
09:34:28 T:140735229206912 NOTICE: The executable running is: /Applications/XBMC.app/Contents/MacOS/XBMC
09:34:28 T:140735229206912 NOTICE: Local hostname: KirbyPro.local
09:34:28 T:140735229206912 NOTICE: Log File is located: /Users/kirbyzhou/Library/Logs/xbmc.log
09:34:28 T:140735229206912 NOTICE: load settings...
09:34:28 T:140735229206912 ERROR: Unable to load libcrystalhd.dylib, reason: dlopen(libcrystalhd.dylib, 1): image not found
09:34:28 T:140735229206912 NOTICE: special://profile/ is mapped to: special://masterprofile/
09:34:28 T:140735229206912 NOTICE: loading special://masterprofile/guisettings.xml
09:34:28 T:140735229206912 NOTICE: Getting hardware information now...
09:34:28 T:140735229206912 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
09:34:28 T:140735229206912 NOTICE: Loaded playercorefactory configuration
09:34:28 T:140735229206912 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
09:34:28 T:140735229206912 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
09:34:28 T:140735229206912 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
09:34:28 T:140735229206912 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
09:34:28 T:140735229206912 NOTICE: Default DVD Player: dvdplayer
09:34:28 T:140735229206912 NOTICE: Default Video Player: dvdplayer
09:34:28 T:140735229206912 NOTICE: Default Audio Player: paplayer
09:34:28 T:140735229206912 NOTICE: Enabled debug logging due to GUI setting (2)
09:34:28 T:140735229206912 NOTICE: Log level changed to 2
09:34:28 T:140735229206912 NOTICE: Loading media sources from special://masterprofile/sources.xml
09:34:28 T:140735229206912 INFO: creating subdirectories
09:34:28 T:140735229206912 INFO: userdata folder: special://masterprofile/
09:34:28 T:140735229206912 INFO: recording folder:
09:34:28 T:140735229206912 INFO: screenshots folder:
09:34:28 T:140735229206912 INFO: thumbnails folder: special://masterprofile/Thumbnails
09:34:28 T:140735229206912 INFO: load language info file: special://xbmc/language/Chinese (Simple)/langinfo.xml
09:34:28 T:140735229206912 DEBUG: trying to set locale to zh_CN.UTF-8
09:34:28 T:140735229206912 INFO: global locale set to zh_CN.UTF-8
09:34:28 T:140735229206912 INFO: load Chinese (Simple) language file, from path: special://xbmc/language/
09:34:28 T:140735229206912 DEBUG: POParser: loaded 2686 strings from file /Applications/XBMC.app/Contents/Resources/XBMC/language/Chinese (Simple)/strings.po
09:34:28 T:140735229206912 DEBUG: POParser: loaded 0 strings from file /Applications/XBMC.app/Contents/Resources/XBMC/language/English/strings.po
09:34:28 T:140735229206912 DEBUG: CCoreAudioHardware::FindAudioDevice: Searching for device - kX SB0350 10k2 [c000].
09:34:28 T:140735229206912 ERROR: CCoreAudioDevice::SupportsMixing: Device mixing support : 'No'.
09:34:28 T:140735229206912 DEBUG: CCoreAudioGraph::CreateMixMap: Source Stream Layout: [Left] [Right]
09:34:28 T:140735229206912 DEBUG: CCoreAudioGraph::CreateMixMap: User-Configured Speaker Layout: [Left] [Right]
09:34:28 T:140735229206912 DEBUG: CCoreAudioGraph::CreateMixMap: Output Device Layout: [Unknown] [Unknown] [Unknown] [Unknown] [Unknown] [Unknown] [Unknown] [Unknown]
09:34:28 T:140735229206912 DEBUG: CCoreAudioMixMap::CreateMap: Unable to locate pre-defined mixing matrix
09:34:28 T:140735229206912 DEBUG: CCoreAudioGraph::Open: Mixer Output Format: 2 channels, 44.1 kHz, 32 bits, 4 bytes per frame
09:34:28 T:140735229206912 DEBUG: CCoreAudioGraph::Open: audioUnit, Input Stream Format [lpcm] Mixable Non-Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
09:34:28 T:140735229206912 DEBUG: CCoreAudioGraph::Open: audioUnit, Output Stream Format [lpcm] Mixable Non-Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
09:34:28 T:140735229206912 DEBUG: CCoreAudioGraph::Open: mixerUnit, Input Stream Format [lpcm] Mixable Non-Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
09:34:28 T:140735229206912 DEBUG: CCoreAudioGraph::Open: mixerUnit, Output Stream Format [lpcm] Mixable Non-Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
09:34:28 T:140735229206912 DEBUG: CCoreAudioGraph::Open: inputUnit, Input Stream Format [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
09:34:28 T:140735229206912 DEBUG: CCoreAudioGraph::Open: inputUnit, Output Stream Format [lpcm] Mixable Non-Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
09:34:28 T:140735229206912 INFO: CCoreAudioAE::Initialize:
09:34:28 T:140735229206912 INFO: Output Device : kX SB0350 10k2 [c000]
09:34:28 T:140735229206912 INFO: Sample Rate : 44100
09:34:28 T:140735229206912 INFO: Sample Format : AE_FMT_FLOAT
09:34:28 T:140735229206912 INFO: Channel Count : 2
09:34:28 T:140735229206912 INFO: Channel Layout: FL,FR
09:34:28 T:140735229206912 INFO: Frame Size : 8
09:34:28 T:140735229206912 INFO: Volume Level : 1.000000
09:34:28 T:140735229206912 INFO: Passthrough : 0
09:34:28 T:140735229206912 NOTICE: Running database version Addons15
Having the same issue here (only left channel audio) but with a MOTU Ultralite mk3 firewire audio device.
19:58:08 T:140735088832896 NOTICE: -----------------------------------------------------------------------
19:58:08 T:140735088832896 NOTICE: Starting XBMC (12.0-RC3 Git:20130102-7a6cb7f), Platform: Darwin OSX (12.2.0 x86_64, Version 10.8.2 (Build 12C60)). Built on Jan 3 2013
19:58:08 T:140735088832896 NOTICE: special://xbmc/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
19:58:08 T:140735088832896 NOTICE: special://xbmcbin/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
19:58:08 T:140735088832896 NOTICE: special://masterprofile/ is mapped to: /Users/b/Library/Application Support/XBMC/userdata
19:58:08 T:140735088832896 NOTICE: special://home/ is mapped to: /Users/b/Library/Application Support/XBMC
19:58:08 T:140735088832896 NOTICE: special://temp/ is mapped to: /Users/b/.xbmc/temp
19:58:08 T:140735088832896 NOTICE: special://frameworks/ is mapped to: /Applications/XBMC.app/Contents/Frameworks
19:58:08 T:140735088832896 NOTICE: The executable running is: /Applications/XBMC.app/Contents/MacOS/XBMC
19:58:08 T:140735088832896 NOTICE: Local hostname: SnooperFax-3.local
19:58:08 T:140735088832896 NOTICE: Log File is located: /Users/b/Library/Logs/xbmc.log
19:58:08 T:140735088832896 NOTICE: load settings...
19:58:08 T:140735088832896 ERROR: Unable to load libcrystalhd.dylib, reason: dlopen(libcrystalhd.dylib, 1): image not found
19:58:08 T:140735088832896 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:58:08 T:140735088832896 NOTICE: loading special://masterprofile/guisettings.xml
19:58:08 T:140735088832896 NOTICE: Getting hardware information now...
19:58:08 T:140735088832896 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:58:08 T:140735088832896 NOTICE: Loaded playercorefactory configuration
19:58:08 T:140735088832896 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:58:08 T:140735088832896 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:58:08 T:140735088832896 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:58:08 T:140735088832896 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:58:08 T:140735088832896 NOTICE: Default DVD Player: dvdplayer
19:58:08 T:140735088832896 NOTICE: Default Video Player: dvdplayer
19:58:08 T:140735088832896 NOTICE: Default Audio Player: paplayer
19:58:08 T:140735088832896 NOTICE: Enabled debug logging due to GUI setting (2)
19:58:08 T:140735088832896 NOTICE: Log level changed to 2
19:58:08 T:140735088832896 NOTICE: Loading media sources from special://masterprofile/sources.xml
19:58:08 T:140735088832896 INFO: creating subdirectories
19:58:08 T:140735088832896 INFO: userdata folder: special://masterprofile/
19:58:08 T:140735088832896 INFO: recording folder:
19:58:08 T:140735088832896 INFO: screenshots folder:
19:58:08 T:140735088832896 INFO: thumbnails folder: special://masterprofile/Thumbnails
19:58:08 T:140735088832896 INFO: load language info file: special://xbmc/language/English/langinfo.xml
19:58:08 T:140735088832896 DEBUG: trying to set locale to en_AU.UTF-8
19:58:08 T:140735088832896 INFO: global locale set to en_AU.UTF-8
19:58:08 T:140735088832896 INFO: load English language file, from path: special://xbmc/language/
19:58:08 T:140735088832896 DEBUG: POParser: loaded 2686 strings from file /Applications/XBMC.app/Contents/Resources/XBMC/language/English/strings.po
19:58:08 T:140735088832896 DEBUG: CCoreAudioHardware::FindAudioDevice: Searching for device - MOTU UltraLite mk3.
19:58:08 T:140735088832896 ERROR: CCoreAudioDevice::SupportsMixing: Device mixing support : 'No'.
19:58:08 T:140735088832896 DEBUG: CCoreAudioGraph::CreateMixMap: Source Stream Layout: [Left] [Right]
19:58:08 T:140735088832896 DEBUG: CCoreAudioGraph::CreateMixMap: User-Configured Speaker Layout: [Left] [Right]
19:58:08 T:140735088832896 DEBUG: CCoreAudioGraph::CreateMixMap: Output Device Layout: [Unknown] [Unknown] [Unknown] [Unknown] [Unknown] [Unknown] [Unknown] [Unknown] [Unknown] [Unknown] [Unknown] [Unknown] [Unknown] [Unknown]
19:58:08 T:140735088832896 DEBUG: CCoreAudioMixMap::CreateMap: Unable to locate pre-defined mixing matrix
19:58:08 T:140735088832896 DEBUG: CCoreAudioGraph::Open: Mixer Output Format: 2 channels, 44.1 kHz, 32 bits, 4 bytes per frame
19:58:08 T:140735088832896 DEBUG: CCoreAudioGraph::Open: audioUnit, Input Stream Format [lpcm] Mixable Non-Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
19:58:08 T:140735088832896 DEBUG: CCoreAudioGraph::Open: audioUnit, Output Stream Format [lpcm] Mixable Non-Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
19:58:08 T:140735088832896 DEBUG: CCoreAudioGraph::Open: mixerUnit, Input Stream Format [lpcm] Mixable Non-Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
19:58:08 T:140735088832896 DEBUG: CCoreAudioGraph::Open: mixerUnit, Output Stream Format [lpcm] Mixable Non-Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
19:58:08 T:140735088832896 DEBUG: CCoreAudioGraph::Open: inputUnit, Input Stream Format [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
19:58:08 T:140735088832896 DEBUG: CCoreAudioGraph::Open: inputUnit, Output Stream Format [lpcm] Mixable Non-Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
19:58:08 T:140735088832896 INFO: CCoreAudioAE::Initialize:
19:58:08 T:140735088832896 INFO: Output Device : MOTU UltraLite mk3
19:58:08 T:140735088832896 INFO: Sample Rate : 44100
19:58:08 T:140735088832896 INFO: Sample Format : AE_FMT_FLOAT
19:58:08 T:140735088832896 INFO: Channel Count : 2
19:58:08 T:140735088832896 INFO: Channel Layout: FL,FR
19:58:08 T:140735088832896 INFO: Frame Size : 8
19:58:08 T:140735088832896 INFO: Volume Level : 1.000000
19:58:08 T:140735088832896 INFO: Passthrough : 0
19:58:08 T:140735088832896 NOTICE: Running database version Addons15
Set XBMC to use 2.0 output and not 2.1. Please post debug logs to pastebin.com and not to the forum.
Also double check that the same speaker config (2.0) is setup in the audio - midi - setup app in OSX.
Memphiz: changing the speaker configuration in the Audio/Midi setup app worked, thank you!
(2013-01-14, 14:15)Memphiz Wrote: [ -> ]Also double check that the same speaker config (2.0) is setup in the audio - midi - setup app in OSX.
Memphiz: changing the speaker configuration in the Audio/Midi setup app worked for me too, thank you!
