Full Version: Lirc Ok button does not work in XBMC 11.0 Eden
Hi there,
I use XBMC "Eden" 11.0 with MythTV and Lirc. My remote control can go up, down, left and right in XBMC. But I cannot trigger any menu item. When I move to a menu item and press Ok on the remote, nothing happens.
I have the Ok button of the remote mapped to XBMC, in ~/.xbmc/userdata/Lircmap.xml I have these settings:
<enter>Ok</enter>
<select>Ok</select>
But still, nothing happens when pressing Ok... Besides XBMC the Ok button works, in a Linux console when pressing Ok it behaves like the enter key on the keyboard. Only in XBMC it does not work.
Do you have any hint for me?
Thanx!
Use either irw or ir-keytable to see what key your remote is sending.
(2013-01-08, 04:58)teeedubb Wrote: [ -> ]Use either irw or ir-keytable to see what key your remote is sending.
irw says the button is named "Ok", so my naming in Lircmap.xml seems to be right...
