Full Version: Option to set MPlayer OR DVDplayer as the default video player?
Pages: 1 2 3 4 5 6 7
ok, so i set the log level to 0 and logged the problem. note that i've removed the configuration part (were the shortcuts are created) to make the log shorter.
there you go:
Quote:21:18:36 m: 55160832 notice: -----------------------------------------------------------------------
21:18:36 m: 55160832 notice: starting xboxmediacenter. built on apr 13 2006
21:18:36 m: 55160832 notice: q is mapped to: harddisk0\partition1\dashboard
21:18:36 m: 55160832 notice: log file is located: q:\xbmc.log
21:18:36 m: 55160832 notice: setup directx
21:18:36 m: 55160832 info: available videomodes:
21:18:36 m: 55160832 info: found mode: 720x480 at 60hz,
21:18:36 m: 55160832 info: found mode: 720x480 at 60hz, widescreen
21:18:36 m: 55160832 info: found mode: 1920x1080 at 60hz, widescreen
21:18:36 m: 55132160 notice: load settings...
21:18:36 m: 55132160 notice: loading t:\settings.xml
21:18:36 m: 55005184 notice: getting hardware information now...
21:18:36 m: 55005184 info: using analog output
21:18:36 m: 55005184 info: ac3 pass through is disabled
21:18:36 m: 55005184 info: dts pass through is disabled
21:18:36 m: 55005184 notice: checking resolution 10
21:18:36 m: 55005184 info: av pack: hdtv
21:18:36 m: 55005184 info: av flags: widescreen,480p,1080i
21:18:36 m: 55005184 notice: setting autoresolution mode 0
21:18:36 m: 55119872 notice: loading q:\xboxmediacenter.xml
21:18:36 m: 55025664 debug: loglevel: 0
21:18:36 m: 55025664 debug: maxretry: 0
21:18:36 m: 55025664 debug: enableshutdown: 0
21:18:36 m: 55025664 debug: protectshares: 0
21:18:36 m: 55025664 debug: mastermode: 0
21:18:36 m: 55025664 debug: startuplock: 0
21:18:36 m: 55025664 debug: lockfilemanager: 0
21:18:36 m: 55025664 debug: locksettings: 0
21:18:36 m: 55025664 debug: lockhomemedia: 0
21:18:36 m: 55025664 debug: debuglevel: 0
21:18:36 m: 55025664 debug: repeat: 480
21:18:36 m: 55025664 debug: move: 220
21:18:36 m: 55025664 debug: repeat: 220
21:18:36 m: 55025664 debug: deadzone: 0.100000
21:18:36 m: 55025664 debug: parsing <myprograms> tag
removed configuration part from log
21:18:37 m: 55099392 info: map drives...
21:18:37 m: 55103488 info: map drive c:
21:18:37 m: 55103488 info: map drive e:
21:18:37 m: 55103488 info: map drive d:
21:18:37 m: 55103488 info: map drive f:
21:18:37 m: 55103488 info: drives are mapped
21:18:37 m: 55103488 info: checking skinpath existance, and existence of keymap.xml:q:\skin...
21:18:37 m: 55103488 debug: setting resolution 0
21:18:37 m: 55103488 debug: we set resolution 0
21:18:37 m: 32501760 debug: setting resolution 0
21:18:37 m: 32501760 debug: we set resolution 0
21:18:37 m: 32501760 info: load language info file:q:\language\english\langinfo.xml
21:18:37 m: 31977472 info: load language file:q:\language\english\strings.xml
21:18:37 m: 31825920 notice: loaded q:\system\players\mplayer\iso639-1.xml
21:18:37 m: 31789056 notice: loaded q:\system\players\mplayer\iso639-2.xml
21:18:37 m: 31789056 info: load keymapping
21:18:37 m: 31789056 info: loading q:\keymap.xml
21:18:37 m: 31752192 info: checking skin version of: project mayhem iii
21:18:38 m: 31752192 info: skin version is: 2.0
21:18:38 m: 31752192 info: gui format 1920x1080 1080i 16:9
21:18:38 m: 31662080 info: install unhandled exception filter
21:18:38 m: 31662080 info: creating subdirectories
21:18:38 m: 31662080 info: shortcuts folder:q:\shortcuts
21:18:38 m: 31662080 info: albums folder:q:\albums
21:18:38 m: 31662080 info: recording folder:q:\recordings
21:18:38 m: 31662080 info: screenshots folder:q:\screenshots
21:18:38 m: 31662080 info: thumbnails folder:q:\thumbs
21:18:38 m: 31662080 info: playlists folder:q:\albums\playlists
21:18:38 m: 31662080 info: subtitle folder:q:\subtitles
21:18:38 m: 31662080 notice: initialize assignment:[dash] network ip:[192.168.1.5] netmask:[255.255.255.0] gateway:[192.168.1.1] nameserver:[0.0.0.0]
21:18:38 m: 31662080 warning: not initializing network, using settings as they are setup by dashboard
21:18:38 m: 31662080 info: init network
21:18:38 m: 31346688 info: get local ip address:
21:18:40 m: 31346688 info: ip adres:192.168.1.5
21:18:40 m: 31346688 notice: xbfilezilla: starting...
21:18:40 m: 29224960 notice: xbfilezilla: started
21:18:40 m: 29224960 notice: checking the date!
21:18:40 m: 29224960 info: - current date is: 25-4-2006
21:18:40 m: 29224960 notice: start dvd mediatype detection
21:18:40 m: 28700672 notice: initializing playlistplayer
21:18:40 m: 28700672 info: lcd not used
21:18:40 m: 28696576 notice: start fancontroller
21:18:40 m: 28172288 notice: load default skin:[project mayhem iii]
21:18:40 m: 28172288 info: load skin from:q:\skin\project mayhem iii
21:18:40 m: 28172288 info: delete old skin...
21:18:40 m: 28172288 info: default 4:3 resolution directory is q:\skin\project mayhem iii\pal
21:18:40 m: 28172288 info: default 16:9 resolution directory is q:\skin\project mayhem iii\pal16x9
21:18:40 m: 28172288 info: skin version is: 2.0
21:18:40 m: 28172288 info: loading skin includes from q:\skin\project mayhem iii\pal\includes.xml
21:18:40 m: 28143616 info: load fonts for skin...
21:18:40 m: 28143616 info: loading fonts from q:\skin\project mayhem iii\1080i\font.xml
21:18:41 m: 27447296 info: load new skin...
21:18:41 m: 27447296 info: skin version is: 2.0
21:18:41 m: 27447296 info: loading skin file: home.xml
21:18:41 m: 27271168 info: loading references file: q:\skin\project mayhem iii\pal16x9\references.xml
21:18:41 m: 27222016 info: loading user windows q:\skin\project mayhem iii\pal16x9\custom*.xml
21:18:41 m: 27242496 info: loading skin file: q:\skin\project mayhem iii\pal16x9\custom1.xml
21:18:41 m: 27238400 info: loading skin file: q:\skin\project mayhem iii\pal16x9\custom3.xml
21:18:41 m: 27242496 info: loading skin file: q:\skin\project mayhem iii\pal16x9\custom4.xml
21:18:41 m: 27242496 info: loading skin file: q:\skin\project mayhem iii\pal16x9\custom5.xml
21:18:41 m: 27242496 info: initialize new skin...
21:18:41 m: 27242496 info: loading skin file: pointer.xml
21:18:41 m: 26894336 info: loading skin file: musicoverlay.xml
21:18:41 m: 26894336 info: loading skin file: videooverlay.xml
21:18:41 m: 26894336 info: loading skin file: dialogvolumebar.xml
21:18:41 m: 26886144 info: loading skin file: dialogseekbar.xml
21:18:41 m: 26841088 info: loading skin file: dialogkaitoast.xml
21:18:41 m: 26841088 info: loading skin file: dialogmutebug.xml
21:18:41 m: 26447872 info: loading q:\skin\project mayhem iii\sounds\sounds.xml
21:18:41 m: 26447872 info: skin loaded...
21:18:41 m: 26447872 warning: curl::curl - url has no protocol ?, empty curl created
21:18:41 m: 26443776 warning: curl::curl - url has no protocol ?, empty curl created
21:18:41 m: 26537984 debug: activating window id: 10000
21:18:41 m: 26066944 info: removing tempfiles
21:18:41 m: 26066944 notice: initialize done
21:18:41 m: 25542656 notice: running the application...
21:18:41 m: 13574144 info: get url: http://rss.elmundo.es/rss/descarga.htm?data2=4
21:18:42 m: 13713408 debug: got rss feed: http://rss.elmundo.es/rss/descarga.htm?data2=4
21:18:42 m: 13713408 debug: rss feed encoding: utf-8
21:18:42 m: 13713408 debug: parsed rss feed: http://rss.elmundo.es/rss/descarga.htm?data2=4
21:18:42 m: 13713408 info: get url: http://feeds.feedburner.com/xboxscene
21:18:44 m: 13611008 debug: got rss feed: http://feeds.feedburner.com/xboxscene
21:18:44 m: 13611008 debug: rss feed encoding: utf-8
21:18:44 m: 13590528 debug: parsed rss feed: http://feeds.feedburner.com/xboxscene
21:18:47 m: 14602240 debug: activating window id: 10006
21:18:47 m: 15654912 debug: freevisualisation() started
21:18:47 m: 15654912 debug: freevisualisation() done
21:18:47 m: 25931776 info: attempting to default to:
21:18:47 m: 25948160 info: loading skin file: myvideo.xml
21:18:47 m: 25755648 debug: cguimediawindow::getdirectory ()
21:18:47 m: 25755648 debug: parentpath = []
21:19:01 m: 17158144 debug: cguimediawindow::getdirectory (smb://192.168.1.106/netfolder/peliculas/)
21:19:01 m: 17158144 debug: parentpath = []
21:19:02 m: 16560128 debug: cvideodatabase::getmoviesbypath query = select * from path join files on path.idpath = files.idpath join movieinfo on files.idmovie = movieinfo.idmovie where path.strpath like '%smb://192.168.1.106/netfolder/peliculas' or path.strpath like '%stack://smb://192.168.1.106/netfolder/peliculas'
21:19:14 m: 16134144 debug: cplayercorefactor::getplayers(smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los mundos.avi)
21:19:14 m: 15630336 info: mplayer playConfusedmb://192.168.1.106/netfolder/peliculas/la_guerra_de_los mundos.avi cachesize:2048
21:19:14 m: 15630336 warning: curl::curl - url has no protocol la_guerra_de_los mundos.avi, empty curl created
21:19:14 m: 9408512 debug: msg: set audio functions called
21:19:14 m: 9408512 debug: msg: done
21:19:14 m: 9670656 info: flipping bi-directional subtitles disabled
21:19:14 m: 9670656 debug: msg:mplayer_init()
21:19:14 m: 9670656 debug: msg:enable mplayer osd
21:19:14 m: 9670656 debug: msg:mplayer dev-cvs-060326-23:36 &copy; 2000-2004 mplayer team
21:19:14 m: 9670656 debug: msg:cpu: intel celeron 2/pentium iii coppermine,geyserville
21:19:14 m: 9670656 debug: msgSadfamily: 6, stepping: 10)
21:19:14 m: 9670656 debug: msg:detected cache-line size is 32 bytes
21:19:14 m: 9670656 debug: msg:cpuflags: mmx: 1 mmx2: 1 3dnow: 0 3dnow2: 0 sse: 0 sse2: 0
21:19:14 m: 9670656 debug: msg:compiled for x86 cpu with extensions:
21:19:14 m: 9670656 debug: msg: mmx
21:19:14 m: 9670656 debug: msg: mmx2
21:19:14 m: 9670656 debug: msg: sse
21:19:14 m: 9633792 debug: msg:
21:19:14 m: 9613312 warning: curl::curl - url has no protocol config, empty curl created
21:19:14 m: 9613312 debug: msg:creating config file: q:\system\players\mplayer\config
21:19:15 m: 9265152 debug: msg:88 audio & 199 video codecs
21:19:15 m: 8249344 debug: msg:mplayer_open_file(smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los mundos.avi)
21:19:15 m: 8249344 info: stating file smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los mundos.avi.conf
21:19:15 m: 7979008 info: stating file q:\system\players\mplayer\la_guerra_de_los mundos.avi.conf
21:19:15 m: 7979008 debug: msg:playing smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los mundos.avi.
21:19:15 m: 7979008 debug: msg:find subtitles
21:19:15 m: 7979008 debug: msg:auto open z:\subtitle
21:19:15 m: 7979008 debug: msg:protocolConfusedmb
21:19:15 m: 7979008 debug: msg:use standard file for protocolConfusedmb
21:19:15 m: 7979008 debug: msg:option stream url: this url doesn't have a hostname part.
21:19:15 m: 5308416 debug: msg:
cache fill: 0.00% (0 bytes)
cache fill: 3.13% (65536 bytes)
cache fill: 6.25% (131072 bytes)
cache fill: 12.50% (262144 bytes)
cache fill: 18.75% (393216 bytes)
21:19:15 m: 5308416 debug: msg:avi file format detected.
21:19:15 m: 5308416 severe: dll: q:\system\players\mplayer\mplayer.dll : malloc failed, crash imminent
21:19:15 m: 5308416 error: cmplayer::openfile() smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los mundos.avi failed
21:19:15 m: 5308416 debug: msg: mplayer_close_file()
21:19:15 m: 5308416 debug: msg: uninit_player
21:19:15 m: 9334784 debug: msg: uninit_player - done
21:19:15 m: 9334784 debug: freeing fs segment @ 0xad4360
21:19:15 m: 15859712 error: playlist player: skipping unplayable item: 0, path [smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los mundos.avi]
21:19:15 m: 15859712 debug: playlist player: no more playable items... aborting playback
21:19:25 m: 16400384 info: loading skin file: dialogcontextmenu.xml
21:19:25 m: 16400384 debug: cplayercorefactor::getplayers(smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los mundos.avi)
21:19:27 m: 16400384 info: loading skin file: dialogcontextmenu.xml
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.utf'
unix_err:'2' nt_err : 'c0000034' error : 'nt_status_object_name_not_found'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.utf8'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.utf-8'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.sub'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.srt'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.smi'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.rt'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.txt'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.ssa'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.aqt'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.jss'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.ass'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.idx'
21:19:29 m: 16121856 info: filesmb->open: unable to open file : 'smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los%20mundos.ifo'
21:19:29 m: 15605760 debug: cpresentthread - starting()
21:19:29 m: 15605760 notice: dvdplayer: opening: smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los mundos.avi
21:19:29 m: 15605760 notice: cdvdplayer::closefile()
21:19:29 m: 15605760 notice: dvdplayer: waiting for threads to exit
21:19:29 m: 15605760 notice: dvdplayer: finished waiting
21:19:29 m: 15081472 notice: creating inputstream
21:19:29 m: 15081472 notice: creating demuxer
21:19:29 m: 15044608 debug: initializing fs_seg..
21:19:29 m: 15044608 debug: fs segment @ 0xad4360
21:19:31 m: 3739648 severe: dll: q:\system\players\dvdplayer\avcodec.dll : realloc failed, crash imminent
21:19:31 m: 3719168 error: cdvdplayer::process - demuxer: error opening, demuxer
21:19:31 m: 3719168 notice: cdvdplayer::onexit()
21:19:31 m: 3719168 notice: dvdplayer: eof, waiting for queues to empty
21:19:31 m: 3719168 notice: cdvdplayer::onexit() deleting demuxer
21:19:31 m: 3719168 notice: cdvdplayer::onexit() deleting input stream
21:19:31 m: 4009984 notice: cdvdplayer::onexit() deiniting subtitle handler
21:19:31 m: 4009984 debug: playback has finished
21:19:31 m: 4534272 error: playlist player: skipping unplayable item: 0, path [smb://192.168.1.106/netfolder/peliculas/la_guerra_de_los mundos.avi]
21:19:31 m: 4534272 debug: playlist player: no more playable items... aborting playback
21:19:31 m: 4538368 notice: cdvdplayer::closefile()
21:19:31 m: 4517888 notice: dvdplayer: waiting for threads to exit
21:19:31 m: 4517888 notice: dvdplayer: finished waiting
what i tried to do is simply go to an external smb stand-alone server drive, for which i've hard coded the ip address, and tried to run the file with the default player (mplayer). i then tried to run this file with the dvdplayer. in both cases the playback failed with no error message shown by xbmc at all.
note that i am running at 1080i (my hd tv does not support 720p, unfortunatelly).
also note that i am able to run this file using the dvdplayer when i access it from an smb drive on my windows xp machine, so xbmc knows how to play the file.
i've skimmed through the log and there seems to be some memory problem? but why would it only happen when i access the file from the stand-alone smb server?
please, any help would be appreciated.
thanks!
angel
so no one can tell from the log that i put here what is the problem when trying to see these video files? do you guys need some additional log or other debug info that i can give you?
amadawn
do you have all of the appropriate codecs installed in the following folder?
xbmc\system\players\mplayer\codecs
you can download a codec pack from yuyu here:
http://johnypcguru.home.mchsi.com/docs/downloads.htm
noumenon
try lowering the resolution to 576 (pal) and see if it'll play.
i think your running out of memmory.
if this works and your determined to run 1080i then start lowering the cache values.
if you start the xbmx hold x-y on the joystick (debug mode) you get a nice memmory available window in the top left.
i've found that running xbmc at 1080i is frought with problems 720p seems the best but ymmv.
i.e you get it working one build then fails again on the next, you really are running it on the edge of it's resources.
i tried with a lower resolution and it also crashed. i also tried fixing the resolution when playing a video to ntsc and it also crashed.
however, i tried opening this video from an smb share on my pc, instead of on a network storage that i am using, and it works. so it may be a samba issue...
angel
well you are running out of memory... disable cache completely and try again.. 1080i takes way too much memory really..
Is there a way to set DVD player as the default player...I ask since i'm able to seek around ftp streams with DVD player....but i have to select play using..dvd player.
i saw this thread:
http://forum.xbmc.org/showthread.php?tid...player+ftp
but could not figure out if these guys were talking about a single file or something else.
thanks...as this would solve my big ftp streaming / seeking issue and stop me from have ing to do a mass converson of tons of movies to a .strm file and http streaming.
yes, if you can code. otherwise, no.
since i only know java and some c....is there anyone who is familar with the code who would be willing compile a onetime copy for me? i'm willing to pay / donate via paypal...
I hope i'm not being out of line with this request, its just this would save me from creating over 2000 .strm files and is thus well worth some $ via paypal or whatever. and i assume its a pretty simple request..
one other thing..i've tried replaceing system->player->mplayer with dvdplayer but the it still uses mplayer...even completly deleting mplayer, xbmc still usese it..how does it still use mplayer if i delete the player->mplayer folder
tks
i just need dvd player to play .avi file since that pretty much what all of my movies are in.
ive been looking at teh 11-02-06 addition to the cvs where someone made dvdplayer the default for .flv
tks
Look in PlayerCoreFactory.cpp
Cheers,
Jonathan
hi,
thanks, i've found the exact codeing needed to change (this is from nov 2 2006 CVS notes..):
Index: PlayerCoreFactory.cpp
RCS file: /cvsroot/xbmc/XBMC/xbmc/cores/PlayerCoreFactory.cpp,v
retrieving revision 1.41
retrieving revision 1.42
diff -C2 -d -r1.41 -r1.42
*** PlayerCoreFactory.cpp    3 Jul 2006 11:55:33 -0000    1.41
--- PlayerCoreFactory.cpp    2 Nov 2006 23:18:20 -0000    1.42
*** 96,99 ****
--- 96,105 ----
+   // force flv files to default to dvd player
+   if (url.GetFileType() == "flv" )
+     vecCores.push_back(EPC_DVDPLAYER);
     if (url.GetProtocol().Equals("daap") || url.GetProtocol().Equals("upnp"))        // mplayer
is better for daap and upnp
except avi, not flv....the issue is i dont have everything set up to compile and i know ppl do their own compiles every day, i was hoping some one could do a compile with this one change...from what ive read it can take a while to get compling fully running, and i would rather not install any more dev tools like .net ect....i was willing to compensate someone for their time as well..
any takers? tks.. i would think there would be other people who would want this, as ftp streaming is the BEST across any medium (net, wifi ect..)..and with this force of dvd player you can get FULLY stable seeking and perfect playback....very nice!
tks
dude it's seriously no big deal to to "get set up" for compiling. I just reinstalled Windows recently so I went from having nothing installed to making XBMC compiles with next to no effort.
I am using Microsoft Visual Studio Net Pro 2003 and Microsoft XBox XDK 5933 Unofficial, and all I did was run the installer for each. VS .NET does install some other prerequisites but they're included on the DVD so it's like "click click done". You need those two and SVN to get the source code of course. After installing those three apps and doing a code checkout, I ran Build.bat successfully the first time. You can do it, it's easy.
HI, I really appreciate the encourgement and it entised me to try...
but here is my point, i've now spent close to 20min trying to find MS .net studio and the XDK kit......maybe i'm stupid...whatever.....its like if some one needed me to do a small change to a graphic in Photoshop...and they dont have p shop or ever use it..or have a need beyond this..takes me like 30 seconds..takes them like 2 hours to find Photoshop..
i know the devs or busy or i would wait for them to implemnt this option normally...
let put it this way, I had compiling set up, I woudl do this for 50$..
how about 50$ to do this for me?
