Full Version: Looking for info on using a TV adapter on my Synology DS410
I'm thinking about testing PVR features on my setup, but I could use some pointers where to start etc.
After reading the PVR FAQ, I'd like to give it a try but I'm not sure which setup is best in my case:
I'm using a Synology DS410 NAS on which my media is stored. There is a TV Headend package availlable which should work. However, I'm clueless which TV adapter hardware I shoudl use on the NAS...?
My tv provider is Ziggo, in the Netherlands, which is a DVB-C provider: I have a coaxial cable and most channels require the use of a smart-card.
I'm not even sure if DVB-C is supported on the Synology DS410, so i't be great of someone could give me some pointers etc Smile
THANKS!
Hi Mikkelnl,
I was wondering if you had more info after you post your question?
This because i was looking for the same setup to use my DS411j with the tvheadend app or buildt an tvheadend "server" from a XMBC buildt for the Raspberry Pi.
Ziggo is also the tv provider to work with.
