In a movie I untick subtiles and save as default
guisettings.xml has this: <showsubtitles>false</showsubtitles>
Yet I get subtiles every time I start a movie
Using 12R3 on a Asrock ION330 with the confluence skin
(2013-01-09, 22:25)uNiversal Wrote: [ -> ]That's probably because the subtitles are part or file or enabled inside the file.
Anyway read this http://forum.xbmc.org/showthread.php?tid=34655
uNi
Right, it's an MKV with subs build in
Not sure what to do with that link though...,
The link its so you can post proper information to begin with
You give no OS post no debug logs etc, and leaves ppl trying to help making guesses, even if the guesses happen to be right.
Anyway you can use mkv merge gui to disable the subs setting the flag from default or enabled to no
XBMC cannot disabled those sorts of subtitles you have to remux the streams.
uNi
Ok I found the default track flag
Thanks for your help !
OK Great!
if you dont mind re-edit your main post and fromthe drop-down-menu next to the thread title select solved.
+1
uNi
