Full Version: Disable Settings Menu
Hi everyone.
I was testing and studying the functions from Transparency 4.0.5 and I disabled settings button in the Main Menu and Shutdown Menu. Confused
How can I access the setting menu nowHuh
Thanks!!!!
two options:
1) add this to your keymap:
<s>ActivateWindow(settings)</s>
2: find this line in guisettings.xml
<setting type="bool" name="skin.transparency.Menu_Settings">true</setting>
and change true to false. this can only be done when xbmc is not running.
Hey Ronie,
I used the second options and works!!!Wink
Thanks!!!
