2013-01-10, 22:52
Hey everyone, good news!
It's long been said that you can't extract images stored in a skin's texture file, but I've found an awesome project on GitHub that does just that. https://github.com/larshall/xbtfextractor
I've only run this on Ubuntu so far, but perhaps some others will have some luck compiling it for other OSs.
Install Instructions:
Usage:
This will extract the contents of the texture file to the directory that you are in currently. Check the GitHub page for other optional arguments that can be passed.
There is still an issue with extracting jpg files as it is possible that the colour channels will be BGR and not RGB so your images may look like they are in a very wrong colour. I have a temporary fix for this. Just a quick python script that you can run. You will need to install PIL for python if you do not have it already:
Install PIL:
bgr_rgb.py:
Usage:
That will cycle the colour channels in the image and make everything look better.
I thought all you skin modders would appreciate this especially. Happy skinning!
sudo apt-get install liblzo2-dev libpng-dev libjpeg-dev libgif-dev git
sudo add-apt-repository ppa:kervala/ryzom
sudo apt-get update
sudo apt-get install libsquish-dev
git clone git://github.com/larshall/xbtfextractor.git
cd xbtfextractor
make
sudo make install
Usage:
xbtfextractor -c /path/to/skin/media/textures.xbt
Install PIL:
sudo easy_install PIL
bgr_rgb.py:
from PIL import Image
import numpy as np
import sys
sub = Image.open(sys.argv[1])
sub = sub.convert("RGBA")
data = np.array(sub)
red, green, blue, alpha = data.T
data = np.array([blue, green, red, alpha])
data = data.transpose()
sub = Image.fromarray(data)
sub.save(sys.argv[1])
Usage:
python bgr_rgb.py /path/to/image.jpg
