Hi, I have new raspberry pi with Xbian installed. It is connected to TV via analog, but texts are too small to clear view. I try to find how to edit Confluence library view (on screenshot) but without success. I want to increase font size in list to 1,5 maybe 2 and limit number of listed movies/tv shows to 7-8. How can I do it?
Not sure if this would help, but for the default Confluence skin I would try looking here:
C:\Program Files\XBMC\addons\skin.confluence\720p\ Font.xml
In there are several names for the fonts. Try increasing the <size> variable one or two numbers higher.
Make a backup of the file first. I don't know if you want to increase all of them, or just specific fonts.
EDIT: I just realized you don't have Windows. So obviously the Font.xml file will be in a different place. Also I don't know how easy it is for you to edit files on that device. Hopefully you'll be able to find a way.
EDIT2: Looks like you can SSH from another PC
http://xbian.org/getting-started/install...nnect/#ssh
Good luck!!
