Full Version: XBMC DAMAGED
Hi all,
Firstly i must say how brilliant XBMC isBig Grin
The problem I'm having is i installed XBMC a few days ago & decided to uninstall it as it wasn't running smooth, now when i try to install it i get the message "XBMC is damaged move to the bin"? im running Mac 10.8.2.
Can any1 help meSad
TIA
Go in your /Applications folder and make sure that there isn't any version of XBMC in it. If there is, move them to the Trash.
Then, download a fresh copy.
Thanks for that but I've already tried that.
(2013-01-12, 16:10)evdok Wrote: [ -> ]Hi all,
Can any1 help meSad
TIA
You need to go in system preferences, security and set allow downloads from anywhere. Right now it is set to only allow downloads from the app store. After you run XBMC you can set the security back to what it was before. XBMC is not signed and that is why you need to do this.
Winestock your the man, thank you it worked a treat.
