Hi All,
just testet Frodo-Release with Openelec. Confluence looks great, but I'm missing a possibility for volume-control within a touchscreen only setup.
anyway - Frodo is a great work...
For touchscreen only setups i would recommend the "touched" skin.
I got a denpendeny error when trying to install re-touched skin. Maybe it can be a problem with openelec as well, cause I've got problems to install other available skins. I think final release of Frodo & openelec will improve things. For me as a xbmc-newbe it's a bit hard to find which skins are possible to install with frodo-release. Touched-skin sources are not inside frodo-tree - just an empty folder. although - I really like the simple clear design of confluence...
testet touched and re-touched skin in frodo - both do lack support for live-tv. so for me it's no alternative
