2013-02-20, 18:37
(2013-02-20, 18:11)psycon Wrote: [ -> ]...SD streams do not play properly at all, all i get is audio, subs, and garbledStrange. Looks like the "MOD16 effect", which should be blacklisted. Could you provide a log, please.
(2013-02-20, 18:37)Koying Wrote: [ -> ](2013-02-20, 18:11)psycon Wrote: [ -> ]...SD streams do not play properly at all, all i get is audio, subs, and garbledStrange. Looks like the "MOD16 effect", which should be blacklisted. Could you provide a log, please.
(2013-02-21, 03:11)CruNcher Wrote: [ -> ]Ehmm Koying couldn't you make this optional as wellHave you read up to the "Advanced Settings" bullet point?
Blacklisting:
(2013-02-21, 08:35)shanti Wrote: [ -> ]FWIW this SD youtube video does not play correctly (garbled screen) on a MK808 using Finles 1.6 ROMGood catch! Looks like the "stride effect" happens when the WIDTH is not MOD16. So I'll have to blacklist those, too.
http://www.youtube.com/watch?v=Qh8BWp6XkvM
(2013-02-21, 12:52)CruNcher Wrote: [ -> ]you have to understand this issueNo. It fails because Rockchip OMX components are using the published width/height of a stream rather than the MOD16 one used by THEIR decoder to allocate THEIR HW buffers we don't have access to.
This padding works fine in the default Android Framework it just fails with 3rd party GPU Render implementations so far
(2013-02-21, 13:16)CruNcher Wrote: [ -> ]Yes thus i guess if you give the decoder what he want's (a mod16 resolution input) there will be no problem with thisYou don't get it, do you? I CAN'T! If you find a way, please submit a patch.
(2013-02-21, 13:16)CruNcher Wrote: [ -> ]So please contact chen im sure hes interested in this, im pretty sure he didn't expected it to be used from outside the Android Framework they createdAn what again, cherry on top?
(2013-02-21, 13:44)movie_enjoyer Wrote: [ -> ]I am confused after looking at several threads and pages. So I ask, Is hardware acceleration playback possible in XBMC Linux on a MK802 A10 device or not?We are here to serve.
