2013-01-21, 04:00
The first folder "Android" can be called other things on various devices. That's why it's suggested to just use the debug log uploader add-on.
TP7-1500DC-metal (RK3066 VPU)
Bitstream XBMC-Hardware 13.01.2013 XBMC-Hardware 18.01.2013 XBMC-Hardware 19.01.2013
Birds f (crash) f (crash) f (crash)
hddvd x (slow >10 fps heavy frame drops) x (slow >10 fps heavy frame drops) x (slow >10 fps heavy frame drops)
Monsters x (1) f (crash) x (6) very slow mega frame drops)
Suzumiya x (2) f (crash) x (7)
Matrix x (3) x (3) x (3)
Harry x (4) f (crash) x (8)
planet x (Decoding errors on end crashes XBMC) x (5) x (5)
shrinkage x (4) f (crash) x (9)
shrinkage 2 x (4) f (crash) x (9)
planet 2 x (4) f (crash)
1 = only subs and audio then stops after 2 seconds loading of another file takes a long time after this
2 = Decoding errors same as with planet + frame jumps forth/back subs wrong placed unstyled after playback crash
3 = CPU XBMC 80%
4 = CPU XBMC 53% Decoding Errors (horizontal tearing ?) same as Planet and Suzumiya same crash @ end
5 = Plays with little amount of Framedrops scaling fails (nearest neighbour)
6 = Plays till Happy Birthday stucks and then restarts the Tablet (yes no Android restart but the whole thing really crashes completely to the on state)
7 = subs wrong placed unstyled scaling fails (nearest neighbour)
8 = CPU XBMC 50% english audio track timestamp issues scaling fails (nearest neighbour)
9 = CPU XBMC 58% scaling fails (nearest neighbour)
http://xbmclogs.com/show.php?id=29321
http://xbmclogs.com/show.php?id=29314
Android 4.1.1
Kernel: 3.08 SMP
Bitstream XBMC-Hardware 21.01.2013
Birds f (crash)
Monsters x (1)
Suzumiya x (2)
Matrix x (3)
Harry x (4)
planet x (5)
shrinkage x (5)
shrinkage 2 x (5)
planet 2 x (5)
1 = CPU XBMC 70% frame drops decoding errors on the top (no crash anymore :) )
2 = CPU XBMC 60% unstyled sub issue else Fluid Playback :)
3 = CPU XBMC 80% (Software Decoder Fallback) Fluid Playback
4 = CPU XBMC 50% english audio track timestamp issues (frame stucks) with Hindi track Fluid Playback
5 = CPU XBMC 60& Fluid Playback :)
(2013-01-22, 02:59)CruNcher Wrote: [ -> ]The VC-1 stream (hddvd) looks like it never reaches RockChips VC-1 Decoder (VC1Decoder) but ffmpeg tries to decode it (else that performance is hardly understandable)
(2013-01-22, 02:59)CruNcher Wrote: [ -> ]It seems also that the more complex the stream the more problematic the monsters with 10 mbps and high profile 4.1 getting this to run without issues would be a big step :-)I assume you tried those with another player and they ran flawless and accelerated?
(2013-01-22, 01:46)saloomhack Wrote: [ -> ]Hi,Please, start by testing and reporting "standard" video files, like the reference ones. Pointless to add points of failure like whatever addon at this state.
just installed the last build and tested it on MK802 III with streamOn addon, video is blurring as seen on this picture
(2013-01-22, 14:11)CruNcher Wrote: [ -> ]Here i tried a Blu-Ray Complexity Stream High ProfileYep, there was a bug playing already annexB h264 like m2ts.
