2013-01-14, 20:23
2013-01-14, 21:08
as per my reply on your other thread, just get mediaportal or whatever program you decide on working with your tv cards and then look into linking xbmc to it. You dont need two different plugins, just use a program like mediaportal where you can set it up with dvb-s and dvb-t.
2013-01-14, 21:35
(2013-01-14, 21:08)moontan77 Wrote: [ -> ]as per my reply on your other thread, just get mediaportal or whatever program you decide on working with your tv cards and then look into linking xbmc to it. You dont need two different plugins, just use a program like mediaportal where you can set it up with dvb-s and dvb-t.
moontan77,
thanks to your help I was able to set up both plugins.
The questionis now:
Can I have a menu item SAT
and a menu item DTT
where in the first case I use the DVB-S plugin and in the second the MediaPortal one?
M
