2013-01-15, 06:50
Hello,
I had issues with recent Ubuntu included Lirc Version.
Lirc coudn't find the kernel modules. In my case that was "mceusb".
After searching around a bit, I found this:
After doing this, the modules are found and xbmc works with MCE Remote Out-Of-The-Box (no keymap.xml config at all needed)
Maybe it helps someone!
cheers Nordish
$ sudo ln -s /lib/modules/$(uname -r)/kernel/drivers/staging/media/lirc /lib/modules/$(uname -r)/kernel/drivers/staging/lirc
cheers Nordish
