Full Version: XBMC trying to use pulseaudio when not installed
Hello all
Frustrating times here. Much of my audio is not playing. I have no pulseaudio installed on the system, but xbmc is quoting "Pulseaudio failed to create context" in the log
I'm not getting any gui error messages - just what shows in the log. No audio on stereo mp3s or video addo-on streaming material.
Machine is a Z-box id41 connected via hdmi.
Running Eden on 12.04.
I am getting sound on surround material and my audio settings are both custom plughw:1,7
If anyone has any ideas, I'd be glad to hear them
debug log (wiki)
(2013-01-15, 08:44)nickr Wrote: [ -> ]debug log (wiki)
Here it is
http://pastebin.com/HeekACi6
as you can see I can get sound on 5.1 recordings from my mythtv install, but nothing happens with mp3 playback or streaming.
Thanks for the help
@jonnybignote:
sudo apt-get remove --purge libasound2-plugins libasound2-plugins:i386
Those plugins add a "pulse" device, which is searching for the pulseaudio daemon. Those must be uninstalled, when you completely want to wipe pulse. After a reboot this message should be gone.
Thanks for that - I still got no audio though - not until I eventually got it working with the following
Audio output to
hdmi:CARD=NVidia, DEV=1
and passthrough to
custom
plughw:1,7
Found this very confusing, as previously, the plughw:1,7 would work for both fields...
Obviously, I get no menu sounds...
