2013-01-16, 15:09
I have a first gen ATV with a CrystalHD 970012 running Eden. By and large it runs very well, but some of my SD files do not play- I get audio but no videa at all. If I Disable the Crystal HD acceleration then the files play normally.
Most of these files were ripped from DVDs I own, so I could re-rip them to a more compatible format- but since this will be most inconvenient I wonder if anyone on here as any other suggestions.
The relevant part of the debug log can be found at http://pastebin.com/6usPBwKA
The files that have problems are PAL resolution non-widescreen dvd rips that were encoded by handbrake using the AppleTV2 preset.
thanks,
Chris
thanks,
Chris
