Full Version: Cannot stream (FREEZING)
Hi, I have tried streaming using many streaming plugins and...
I can't.
It streams PERFECTLY for about 2-3 minutes, and then freezes. This is a very interesting freeze, however, because it will let me press the Back button and move around within the while-playing-menu, but when I press stop, pause, rewind, fastforard (mostly I press STOP), it completely freezes and won't allow any input, and I have to kill it from the command line. Meanwhile, if I don't select an option withNaviX, SportsDevil, P the menu, both the audio and video remain frozen, indefinitely.
This has happened since I initially installed the system (about a year ago), and it's been on going since. I've just recently decided to try to fix it... and I failed.
I'm hoping someone here can help?
Here is the info you guys need, I hope:
DEBUG LOG: http://pastebin.com/P4hn0t1y
OS: Linux 3.2.0-30-generic-pae #48 =-Ubuntu SMP
XBMC VERSION: 11.0 GIT:UNKNOWN (COMPILED : APR24 2012)
Thanks so much,
Mike
Thanks, please consider this thread closed.
You can mark it as "solved" by editing the first posting in your thread.
Next to "subject" is a pulldown menu, where it can be marked.
Thanks so much!! Smile
